Inexpensive Analog Capture for Premiere at DVinfo.net
Adobe Creative Suite
Old June 10th, 2010, 04:22 PM   #1
Looking for an analog capture device that I can plug USB or Firewire that Premiere CS4 or CS5 will recognize.
In searching through Newegg I see many products that come with crapware, but I'd like to capture straight from Premiere without having to load additional software...
Jason McGovern is offline   Reply With Quote
Old June 10th, 2010, 08:09 PM   #2
I'd recommend the Canopus Converter.... The ADVC110 has been around for awhile.
You can of course spend more, depending on your needs, but you'll essentially be digitizing to the DV codec.
Premiere will cut through DV like butter...
Good luck!!!
Old June 10th, 2010, 09:50 PM   #3
I use a cheap sony mini-dv camcorder with a pass-through analog to digital.
Jun
Sony Z7U, Canon 5D Mark II, Canon 24-105 F4L, Canon 70-200 F2.8L, Canon 580 EXII, Zoom H2.
Jun Galinato is offline   Reply With Quote
Old June 10th, 2010, 11:06 PM   #4
What about the BlackMagic Design USB Video Recorder? It looks simple enough.
Blackmagic Design: Video Recorder
Craig Coston is offline   Reply With Quote
Old June 12th, 2010, 10:16 AM   #5
Premiere only captures through firewire.
I second the Canopus (Grass Vally).
Old June 12th, 2010, 10:55 AM   #6
Third the Canopus (Grass Valley) analog>FW converters. I have 3...they just work.
...we ARE talking about standard def, right?
TimK
Kolb Productions
Tim Kolb is offline   Reply With Quote
Old June 13th, 2010, 09:24 AM   #7
AVC110 converter on Firewire
I have had one of these for 5 years. For most of that I was on XP and a motherboard with FireWire800 ports and the capture would periodicly "drop out". I would then have to backtrack and restart capture. I am now on Win7-64 and CS4 with a motherboard that seems to have FireWire400 only ports.....and the capture works flawlessly!
Don Blish is offline   Reply
