Reusing Sequences in New Projects at DVinfo.net
Adobe Creative Suite
Old November 10th, 2010, 09:24 PM   #1
Is there a way to import a sequence from a previous project to a new project in Premiere? As an example, in Avid Liquid you can set up a sequence or several for that matter, that contain elements that you use regularly as a template and have a new project start with it. Alternatively you can select a project that was done previously from within a new project and copy and reuse anything you wish including titles, clips and whole sequences. Is there anything similar in Premiere?
David Jonas is offline   Reply With Quote
Old November 11th, 2010, 05:42 AM   #2
File/import/select project. You can choose the whole project or select sequences.
Old November 11th, 2010, 06:06 AM   #3
Thanks a lot. I had actually looked at that many times but because the file types field showed only media, I never realized you could import a project.
Old December 7th, 2010, 06:41 PM   #4
Adobe Systems
More Info about Re-using Sequences in New Projects
Hi Gang,
It's Kevin from Adobe Learning Resources. Need to re-use a sequence in a new project? This thread explains how easy it is. However, if you would like more info about re-using sequences in new projects, check out this page from Adobe Premiere Pro CS5 Help.
Adobe Premiere Pro CS5 * Import selected sequences from Premiere Pro projects
Kevin Monahan is offline   Reply
