simple crop and border with Premier CS5 at DVinfo.net
Adobe Creative Suite
Old March 8th, 2011, 11:06 PM   #1
The latest version of Adobe CS5 doesn't include many of the simplest effects that CS4 has. One is to just add a border, size, choose color and crop. I can hardly believe this very rudimentary yet useful effect is no longer there.
Even New Blue Effects doesn't have this option and feature.
How are any of you doing this?
Bob
Bob Kreider is offline   Reply With Quote
Old March 8th, 2011, 11:52 PM   #2
Re: simple crop and border with Premier CS5
Totally flying blind here, as I have CS4 and can't identify the tool you're speaking of, but here is a possible workaround: CS5 still has the crop tool, according to the cs5 help file. So crop. In Titler, make a rectangular box covering the video image you just cropped. Select "eliminate" in the type popup. In the stroke field, select Outer>add; select color in the color swatch and make the size to cover the frame outside the video image. See attached jpeg.....
Sounds like there must be an easier way....and forgive me if I have misinterpreted what it is you're trying to do...
Old March 9th, 2011, 03:11 AM   #3
If Battle's image is the look you are looking for, then the simplest suggestion would be to add a sold colour matte on the lower track, with the footage above it. Then simply crop or scale down the footage.
Kevin Currie is offline   Reply With Quote
Old March 9th, 2011, 01:46 PM   #4
I think Bob means the Clip effect: that was last used in Ppro2.
Old March 9th, 2011, 11:36 PM   #5
Good on Kevin, I should have thought of that....aaargh!
Old March 10th, 2011, 05:46 AM   #6
Make sure you untick scale and set it manually because it does not make a perfect even boarder.
Then nest the two images and motion, scale or rotate as much as you like.
Ann Bens is offline   Reply
