DVD Authoring Question at DVinfo.net
Adobe Creative Suite
Old November 17th, 2011, 11:28 AM   #1
Okay, so here's my dilemma. I need to burn a 1.5 hour DVD to run in a monitor as a background. My source video is about 34 minutes of uncompressed AVI 720p HD footage. I have tried dropping it in an SD widescreen timeline and exporting an MPEG-2 DVD format file, exporting an MPEG-2 DVD file straight from the HD timeline, and I have sent the project to Encore. I haven't used Encore before, but have been on DVD Studio Pro in FCS for several years, so a lot of things transfer over.
Is there a way to do this that doesn't involve several hours of rendering, encoding, and exporting? I also will probably have to do this with other projects as well and want to develop a decent workflow that I can pass along to others. We also have Windows DVD Maker on the machine. Would it be easier to just export an SD AVI and let that do the chewing? These are not meant to be high-end DVDs. They are just to get the footage onto something playable.
Mark
Mark Hendren, Mark Five Productions
www.markfiveproductions.com
Mark Hendren is offline   Reply With Quote
Old November 17th, 2011, 12:00 PM   #2
Re: DVD Authoring Question
One way or another you have to transcode your file to MPEG-2, but do it this way: import premiere project to Encore via dynamic link, place the 34-min. sequence in a loop mode (it will run indefinetly until it is turned off) or place the sequence three times in a timeline. Either way the encoding will only happen once for the 34-min sequence, and you'll get the best quality.
Alternatively you can export the 34-min. sequence to SD AVI and let Encore handle MPEG-2 encoding, but one way or the other you'll cut your rendering time seriously.
Creative Impatience - The Solace of Simple Solutions. A few useful plugins for Adobe users, and my remarks on the tools and the craft in general.
Bart Walczak is offline   Reply With Quote
Old November 17th, 2011, 03:30 PM   #3
Hi Mark,
If you have a decent PC workstation, such as any Core i7 machine, it should take less than an hour to encode AND burn the DVD, not "several hours". For encoding, just use CBR 7.0 data rate, multi-pass VBR unnecessary.
What are your system specs? Premiere version?
Jeff Pulera
Safe Harbor Computers
Mark
Jeff Pulera is offline   Reply
