Change framerate on stock footage. at DVinfo.net
Adobe Creative Suite
Old November 17th, 2011, 10:33 PM   #1
Hi
I bought some stock footage from Footage firm. The material is 1920x1080 29,97fps mov clips. Seems not to be intelaced.
What I need - is to konvert them to 25 fps. Normally I just change the framerate in modify/interpret footage.
It changes the way the files playback but they still are jumpy and CS5 seems to double every 5'th frame.
Even after rendering.
25:5 =5 5x6=30 cannot figure if this has anything to do with the extra 5'th frame.
Bo Skelmose is offline   Reply With Quote
Old November 18th, 2011, 09:53 AM   #2
Re: Change framerate on stock footage.
You can change the framerate correctly in AE with the plugin Timewarp or Twixtor.
Bogdan Nicolau is offline   Reply With Quote
Old November 18th, 2011, 12:44 PM   #3
Hi
Tried twixtor and AE to do it but the error is there before I try to change the speed back.
When I change framerate in interpret footage - it should play smooth.
Twixtor should only be used to get the speed back right.
