After Effects CS6 (11.0.1) and Premiere Pro CS6 (11.0.1) updates available at DVinfo.net
Adobe Creative Suite
Old May 24th, 2012, 11:53 PM   #1
Adobe Systems
After Effects CS6 and Premiere Pro CS6 bug-fix updates are available, with performance improvements and some new features. Details here: updates for Adobe Media Encoder, Premiere Pro, After Effects, Prelude, and SpeedGrade Premiere Pro work area
Install the updates and let us know how they work for you. They should solve a lot of problems.
Todd Kopriva, Adobe Systems Incorporated
After Effects quality engineer
Todd Kopriva is offline   Reply With Quote
Old May 25th, 2012, 04:22 AM   #2
Re: After Effects CS6 (11.0.1) and Premiere Pro CS6 (11.0.1) updates available
Just installed it and now Premiere no longer works.
Software stops loading at "Loading ExporterQuickTimeHost.prm
EDIT: Now loads up but takes a lot longer to do and seems to stall at the above point.
Syeed Ali is offline   Reply With Quote
Old May 25th, 2012, 06:50 AM   #3
Same here. it hangs at the same point. how does adobe let these things out with catching this kind of stuff?
mine still has not finished loading and has been stuck on the item for awhile now.
Sony Fan Boy! Sony AX100, VG20, RX10, A6000, CX760 and a GoPro 4
Dan Tolbertson is offline   Reply With Quote
Old May 25th, 2012, 05:54 PM   #4
Adobe Systems
I've seen a couple of reports of this, and they were resolved by uninstalling and then re-installing, and then re-applying the patch.
In all of the cases that I've seen, it occurs when you apply the update with Premiere Pro running, as opposed to running the updater from Bridge as recommended.
Old May 28th, 2012, 01:15 AM   #5
Since the update Premiere CS6 has become very buggy. It hangs when playing back AVCHD on my MacBook Pro when using the hardware CL mercury engine. It's basically unusable after applying the patch.
Old May 28th, 2012, 01:19 AM   #6
Adobe Systems
What operating system?
If Mac OS, we very strongly recommend Mac OSX v10.7.4. Apple made some fixes for OpenCL that coordinate with fixes that we made in the 6.0.1 update.
Old May 28th, 2012, 08:42 AM   #7
That did not work for me. it still hangs after re installing (through Bridge) i really think it may be boiling down to a Norton issue? that seems to be a common denominator from what I am reading.
Old May 28th, 2012, 10:38 AM   #8
Same here. Norton quarantines a file from CS6 incorrectly. Adobe are hopefully getting Norton to fix this. Restoring the file didn't help me. Load time was 5 mins plus, sitting looking at that QuickTime plugin name on the splash screen.
PP was not running during the update.
I deleted that QuickTime plugin that it hangs on (keeping a backup) and loading seems OK now. I'm assuming that I've lost some functionality to do with QuickTime, but that's not a biggie for me. I'm in the middle of some projects and another reinstall isn't appealing right now.
Old May 28th, 2012, 01:27 PM   #9
Do these updates fix the issue for when I load a CS6 project I get a error message that says something to the effect... " quicktime does not support this screen resolution" ??
Old May 28th, 2012, 05:58 PM   #10
Adobe Systems
It does appear that Norton is blocking things incorrectly here. I'll see if I can get this information to the right folks to address it.
Old May 29th, 2012, 12:03 AM   #11
It is Norton. I had to add c:\program files (x86)\common files\Adobe\installers\adobetemp\ to Signatures to Exclude from All Detections to get it to work.
btw, I agree. AVCHD file playback and jumping on the timeline is horrendously slow. I had to convert all my .mts files to mp4 just so I could complete a project. CS5.5 didn't have this problem. Several threads on the adobe forums about the problem.
Kawika Ohumukini is offline   Reply With Quote
Old May 29th, 2012, 01:39 AM   #12
On Windows 7 64 bit, my 1080/50p MTS files are playing as well as ever.
I actually find the performance better than CS5, and rendering seems faster too - and I don't have a fancy Nvidia graphics card either.
To the Norton-bashers, every anti-virus software occasionally has false positives. At my work we've had to contact Norton, Mcafee and others to get our perfectly safe files off the black-list - software that works perfectly just stops some day after an update. It's just by chance that this time it's Norton flagging an incorrect file.
Old May 29th, 2012, 09:18 AM   #13
Adobe Systems
This morning, one of our engineers will submit some new information to Norton that should (nearly) immediately clear the files in our updater from being flagged for quarantine. This means that the next time that the Norton antivirus software runs, it shouldn't mis-identify these files as problematic. However, people for whom this has already occurred will need to either manually un-quarantine these files or uninstall and reinstall Premiere Pro CS6 and the update.
Old May 30th, 2012, 07:53 AM   #14
Adobe acknowledged the problem here. Seems large files reveal the problem.
...To the Norton-bashers, every anti-virus software occasionally has false positives.
Also acknowledged by Adobe and they're working with Norton, good work guys. I didn't read any bashing unless you mean this.
Cheers
Old May 30th, 2012, 10:37 AM   #15
Sorry, I was mixed up - the Norton bashing was on the Adobe forum, not here. Problem with my dreadful short-term memory!
Mike Beckett is offline   Reply
