Premiere Pro CC - How to get 2 separate channels on timeline at DVinfo.net
Adobe Creative Suite
Old March 7th, 2014, 09:04 AM   #1
Before, two separate channels of audio would be on the timeline (A1 & A2) when I moved it from the project window.
Now, both channels are in A1 and I can't figure out how to get it back to the old way.
Files are MXF
Properties are:
Source Audio Format: 48000 Hz - 16 bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Screenshots below
Premiere Pro CC - How to get 2 separate channels on timeline-before.jpg   Premiere Pro CC - How to get 2 separate channels on timeline-after.jpg
Syeed Ali is offline   Reply With Quote
Old March 7th, 2014, 11:28 AM   #2
Re: Premiere Pro CC - How to get 2 separate channels on timeline
To clarify, was that before and after an update to premiere pro cc?
Stephen Brenner is offline   Reply With Quote
Old March 7th, 2014, 12:03 PM   #3
There used to be a "Break out to mono" command. Maybe still is. Select the track and either right click on it or go through the menus and it should be somewhere.
Sorry, don't have CC; still on PP CS5.
Edit: It's under Clip/Audio Options/Breakout to Mono in CS5. It might just put these into your Project Panel and you might have to drag these onto your timeline.
Old March 7th, 2014, 01:39 PM   #4
Last update was 63 days ago.
Everything was working fine since then.
It still works ok on the old projects.
No it's not that.
I think it has something to do with the way Premiere is importing the audio files. I've tried various options in PREFERENCES > AUDIO but nothing seems to work.
Old March 7th, 2014, 01:44 PM   #5
Problem sorted.
This video helped
MediaStorm Guide to Audio Configuration in Premiere Pro CC
Old March 8th, 2014, 01:43 PM   #6
This usually works for me:
-Right click on your footage in the project window
-Go to Modify -> Audio Channels
-Set channel format to Mono
-Set number of audio tracks to 2
Then drag that footage into a sequence and it should have 2 audio tracks.
You can also go to edit -> preferences -> audio and change the Stereo Media option to Mono. That should force files with stereo audio onto 2 tracks for any footage that you import in the future, don't think it'll affect footage already in the project.
Chris Thompson is offline   Reply With Quote
Old December 22nd, 2014, 07:45 PM   #7
Once you've broken them out to two different mono channels, is there anyway to get them back to one stereo clip?
Matt Hoecker is offline   Reply
