Premier Pro 2 Crashes - HELP at DVinfo.net
Adobe Creative Suite
Old March 5th, 2006, 04:11 PM   #1
I have been using Premier Pro 2 for a couple weeks now without incident. However, today I attempted to use the titler for the first time and premier crashed after I typed a couple letters. I tried again and it crashed as soon as I clicked to add a title. I restarted the computer and tried again, but it is still crashing.
Does anyone else have this problem or know a solution?
Adam Grunseth is offline   Reply With Quote
Old March 5th, 2006, 05:18 PM   #2
I've been using PPro 1.0 for the last couple of years and the titler was always the one thing that would get it to crash (rarely anything else). Was hoping that was fixed in 2.0, but it appears not.
Earl Thurston is offline   Reply With Quote
Old March 5th, 2006, 07:22 PM   #3
That's odd. I haven't noticed the titler causing stability problems in Premiere Pro 1.5, and I can't remember it causing Premiere Pro to crash in version 1, either.
Christopher Lefchik is offline   Reply With Quote
Old March 6th, 2006, 09:06 PM   #4
I figured it out
I figured out a work around so that the titler would not crash on me. For whatever reason when my camera is connected to the fire wire and turned on, the titler will crash. All I have to do is unplug the camera or turn it off and it works fine. This is the only issue I've had.
Old March 7th, 2006, 09:50 AM   #5
Hmm, interesting. Maybe it's an issue with Premiere trying to output the titler preview through your FireWire device? I'm running an RT.X100 so my preview setup is a little different. ;-)
Old March 9th, 2006, 07:41 AM   #6
I've Had No Titler Problems
Believe me, I've had my issues with PPro 2.0 but I strongly recommend the Adobe website forums board. You would not believe how helpful it has been. And, it is very easy to use. Just register (for free) and you can post any question. It has been my experience that every issue I've discovered in PPro 1.5 and 2.0 had already been posted, discussed and solved online by others willing to help. Give it a try. It really works.
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply
