Need 16:9 mask for Premiere Pro 1.5 at DVinfo.net
Adobe Creative Suite
Old May 3rd, 2006, 11:31 AM   #1
Has anyone made or is there available a 16:9 mask in PP1.5?
I am shooting 4:3 and making a 4:3 project, but would like to letterbox in post in case someone has a 16:9 display.
www.facebook.com/projectspecto
Marco Wagner is offline   Reply With Quote
Old May 3rd, 2006, 11:37 AM   #2
Hi Marco,
try a search on this forum, its appeared a couple of times.
Our very own Rob Lohman has some on his web site, but I can't remember the link. there is also a widescreen matte in title designer but i'm not too sure if its true 16x9.
cheers,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old May 3rd, 2006, 12:01 PM   #3
Thanks, I've search a couple times, but am probably not using the right key words, I keep getting discussions of 16:9 only, not many masks.
Old May 3rd, 2006, 12:20 PM   #4
The titler has a template you can put on top.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old May 3rd, 2006, 12:40 PM   #5
Here's a link to a ZIP file on my site that has several SD mattes in PSD format, including a 16x9:
http://www.chewbode.com/Portals/0/Pr..._Plates_SD.zip
Matt DeJonge is offline   Reply With Quote
Old May 3rd, 2006, 01:56 PM   #6
Marco,
You don't necessarily need a matte. You can drop your sequence into a new sequence and put a "Crop" or "Clip" video effect on the whole sequence. I think you need to trim off about 60 pixels or about 12.5% off the top and bottom. I usually call the new sequence "Letterbox" and pop over to it occassionally to preview and ensure my clips are positioned correctly in the letterbox.
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old May 3rd, 2006, 05:29 PM   #7
If you decide to crop or clip the video, these are the SD resolutions you could use, depending on the look you're going for:
720 x 480 = Standard Def (1.33:3)
720 x 350 = Academy Aperture (1.37:1)
720 x 270 = Widescreen TV 16 x 9 (1.78:1)
720 x 259 = Flat/Academy Aperture (1.85:1)
720 x 204 = Scope (2.35:1)
Old May 3rd, 2006, 06:07 PM   #8
Thanks for the quick responses and solutions folks, much appreciated.
Old May 3rd, 2006, 10:44 PM   #9
Matt, your numbers are way off, sorry. I don't have the time to work them out perfectly right now, but Academy is going to be closer to 472 tall, Widescreen 364, Flat 350, Scope 275, all 720 wide in 4:3 SD.
Old May 10th, 2006, 10:46 PM   #10
Hey which of these is best to use. The Widescreen 1.78 mask or the Letterbox Academy 1.37? It seems like the academy 1.37 has much more viewable space, but will some be lost on a widescreen TV "zoom"?
Old May 11th, 2006, 12:17 AM   #11
I found some of these replies using the key words "convert standard widescreen" in the search. I hope they help. :o)
http://www.dvinfo.net/conf/showthrea...ard+widescreen
Tom Bolia is offline   Reply With Quote
Old May 11th, 2006, 12:51 PM   #12
Marco,
For widescreen, you want 1.78, that is roughly the ratio of 16:9 HDTV. Academy 1.37 is almost the same as standard 4:3.
Josh
Old May 11th, 2006, 01:41 PM   #13
Thank you. I am assuming then with the 1.78 a "widescreen zoom" will fill the whole screen, which is what I am looking for.
Thanks Tom, for the links.
Old May 11th, 2006, 03:54 PM   #14
Joshua, you are totally correct! OMG! I guess when you want something done right, you have to do it yourself - I shouldn't have relied on the info I had but calculated it out myself...
Well, I think these are the accurate resolutions (I think the other calculations didn't take 0.9 pixels into consideration). Assuming 640 x 480 is your 0.9, NTSC resolution, your computer pixel aspect ratio (1.0) video would be:
720 x 467 = Academy Aperture (1.37:1)
720 x 360 = Widescreen TV 16 x 9 (1.78:1)
720 x 346 = Flat/Academy Aperture (1.85:1)
720 x 272 = Scope (2.35:1)
If DV is 720 x 480, and you "convert" this to 0.9 broadcast aspect, you'd get 648 x 480, right? What's up with that 8-pixel horizontal resolution discrepancy?
Anyway, I guess I'll need to go fix my letterbox mattes now. :(
Old May 12th, 2006, 11:21 AM   #15
Matt,
Yep, now it looks right. Assuming 4:3 source, cropping down to the various ratios. Would be different for 16:9 source, of course, where you have some flexibility to stick with 720 wide, go to 864 wide, or do something else entirely.
Josh
