FX1 + PPro 2.0...it ain't workin'! at DVinfo.net
Adobe Creative Suite
Old May 9th, 2006, 05:59 PM   #1
Images: 1
What's the deal? I've tried all the tricks (looking for audio codecs to uninstall, selecting "HDV" in the menu instead of "Auto", uninstalling the registry entries for IEEE1394). I Select DV Capture under capture format, then under DV/HDV Device Control I Select Sony, and leave it Generic. I get a "Can't Activate Recorder. Try Resetting Camera" error and no matter what I do, it doesn't change. It controls the camera fine, but it refuses to capture! Gahh! Help?
BenWinter.com
Ben Winter is offline   Reply With Quote
Old May 9th, 2006, 06:13 PM   #2
Images: 1
Whoa! Sadly the problem has corrected itself. I say sadly because I don't know what I did (nothing) so if it happens again I'm sunk.
BenWinter.com
Old May 9th, 2006, 06:17 PM   #3
Images: 1
Nope! Just kidding--spoke too soon. Had it for a second and then lost it. Back to the "can't activate..." nonsense.
BenWinter.com
Old May 12th, 2006, 12:37 AM   #4
Several items could cause this. Perhaps your firewire card isn't using the correct drivers, i.e texas instruments or OHCI MS. Which I have seen happen in the past.
The later might be best explained here:
http://www.adobe.com/support/techdocs/330682.html
Now if you already did that.. Then I could only suggest uninstalling PPRO and reinstalling. If that fails, nothing like a fresh OS install..
Pat Sherman is offline   Reply With Quote
Old May 12th, 2006, 08:39 AM   #5
Images: 1
That fixed it! silly me...should've thought of that before.
BenWinter.com
