Slow-motion jitter at DVinfo.net
Adobe Creative Suite
Old October 30th, 2006, 07:38 PM   #1
'Field Bob' problem - eliminating slow-motion jitter?
When I slow down a clip in Premiere, there is a pronounced vertical jitter in the resulting exported footage. Apparently this is called 'field bob', caused by the slight vertical shift between interlaced frame halves. I did some searching and tweaking of settings but wasn't able to find a fix. Has anyone found a solution to 'field bob' in Premiere?
Here is a sample of what happens (clip is 2.4MB full-screen WMV):
http://wvlightning.com/stuff/slomojitter.wmv
Thanks in advance for any advice!
Dan Robinson is offline   Reply With Quote
Old October 30th, 2006, 11:52 PM   #2
Another bit of info - unchecking 'Frame Blend Speed Changes' and choosing 'flicker removal' in the Field Options window removes the 'field bob' but also removes the smoothing between frames, creating a more 'stepped' appearance rather than a smooth slow-motion image.
Old November 1st, 2006, 01:12 PM   #3
One last bump to see if anyone has had this problem.
Old November 1st, 2006, 07:57 PM   #4
Slow motion with video is never that great. Best option that I know of is to just shoot in 60i and pray. Maybe try some software like Shake. But I have no experience with it.
Adam Bray is offline   Reply With Quote
Old November 8th, 2006, 03:07 PM   #5
slo mo
The best program out there for slo mo is twixtor, but it is a few hundered bucks.
I am not sure shooting in interelaced is the best to make slow mo. I use 30 p and it is reasonable.
DATS ALL FOLKS
Dale W. Guthormsen
Old November 10th, 2006, 09:59 AM   #6
Adam is right in that slow-mo on video is never good. However, I found a decent alternative if you can't frame ramp with video. Shoot in 60i with a shutter speed of 1/120 to get the crispest image. Use field interpolate on the 60i image in your timeline and save as a 24p or 30p, whatever you're using, lossless file. Import that file into your finished product and it should work. Don't take this as scripture. I've only done it once and I've probably forgotten a few steps, but try it out and let me know.
Section 1 Films
Joshua Clarke is offline   Reply With Quote
Old November 10th, 2006, 11:29 AM   #7
Dale is right, Twixtor is awesome.
Cal Johnson is offline   Reply With Quote
Old November 14th, 2006, 03:21 AM   #8
Do you mean that it looks like the camera is shaking up and down, like it's not on a steady tripod?
http://www.darkbyke.deviantdesign.ca
Canon Elura 65
Adobe Premiere 1.5 Pro
Song VAIO PC / 3GHz / 1.5GB ram / 710GB capacity
Calvin Wallace is offline   Reply With Quote
Old November 14th, 2006, 07:32 AM   #9
You could use my filter for VirtualDub to turn the footage from 60i to 60p and then use that in a 24p/30p timeline in PPro. It will give you super smooth slowmo.
It's not the same as doing it inside Premiere bu they're both free, fast and very easy to use.
http://www.geocities.com/headlesspup...f/vdub_60p.zip
http://www.virtualdub.org/
Good luck.
Do or do not, there is no try.
Dave Ferdinand is offline   Reply With Quote
Old November 15th, 2006, 02:17 AM   #10
Images: 1
Also, "motionperfect" from dynapel interpolates frames to give extra-smooth slow-mo. I use my music video "one headlight" at http://qt.frozenphoenixproductions.com as a great example of what it can do.
BenWinter.com
Ben Winter is offline   Reply
