Sequences need rendering again? at DVinfo.net
Adobe Creative Suite
Old February 27th, 2007, 08:33 AM   #1
Hi, I have PPro 1.5 project containing a series of sequences which are all rendered with no problems.
I then imported all the sequences into another sequence assuming that as they were already rendered, to render this compilation sequence would take a matter of seconds, not so, it seems everything has to be rendered again..?
Dan Burnap is offline   Reply With Quote
Old February 27th, 2007, 02:09 PM   #2
My understanding is that with any NLE the clips in your timeline are really just sets of instructions about where to go and what to do with the data to render a project. It's all virtual until you output to a file...
But I could be misinformed...
Old February 28th, 2007, 04:13 AM   #3
If you copy/paste it will remain rendered but if you insert a sequence into another sequence, then it will have to render again.
It's a hindrance unfortunately.
Bart Walczak is offline   Reply With Quote
Old February 28th, 2007, 11:31 AM   #4
Thanks chaps
Old February 28th, 2007, 01:24 PM   #5
I whish I knew this last night... I knew it won't re-render if I copy and paste, used that in the past, but "it didn't click" why it's re-rendering when nesting a sequence into another one. I was working on a DVD directly from inside PPRO 2.0 and having my movie broken up into shorter sequences, it was the only way I was able to do it.
Oh well, this is why I spend time on this forum... to learn... Luckily I had other things to do in the meantime so I just let PPRO to do it's thing; it dind't take an awful lot.
Ervin Farkas
www.AtlantaLegalVideo.com
Old February 28th, 2007, 04:54 PM   #6
Nested sequences require rendering. That is "As Designed". But hopefully will be one of the design changes eventually, if not the next release.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old March 1st, 2007, 08:22 AM   #7
Images: 57
At least when you move a pre-rendered clip on the same timeline, it keeps all or a portion of the preview. It wasn't the case before. So, yes, would be nice to have clip reference back to their previews when nested.
Pete Ferling http://ferling.net It's never a mistake if you learn something new from it.
Peter Ferling is offline   Reply With Quote
Old March 1st, 2007, 05:01 PM   #8
My project was made up of 24 songs filmed from a concert. I split them up into a sequence for every show just to make my life simpler and faster. For the final output though I just wanted one avi of the whole lot, hence why I was importing sequences into one back-to-back.
In the end I gave up after an estimated rendering time of about 60 years and took advantage of Encore 2's 'playlist' feature using the individual song avi's, saved a of time and I didnt have to insert chapters markers either.
