Battery Solution for AJA KiPro - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old October 7th, 2011, 01:52 AM   #16
Re: Battery Solution for AJA KiPro
Thanks Jon. One pair of supporting rod mounts is certainly strong enough for the Mini + 2 mounting plates + AB Dionic 90 battery which weighs about 2 lbs. My concern was if I use the Hytron 140 battery which weighs about 5 lbs, would I need another pair of rod supporting mounts on the other mounting plate to support the extra weight?
Brian Lai is offline   Reply With Quote
Old October 7th, 2011, 03:58 AM   #17
The KPM with AJA Cheese Plate works well on the shoulder or on a tripod.
Steve Cocklin is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
