Reloading clips onto Ki Pro at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old September 10th, 2011, 02:12 PM   #1
I think I'm correct in thinking that you can use the Ki Pro Mini as a playback device - ie once you've recorded clips onto the card you can hook it up to a monitor, press Play and it'll play.
What I was wondering was once you've transferred the material from the card to a hard drive (in a folder presumably) could you then reload a folder onto a card and play it?
Cheers,
Steve
Old September 10th, 2011, 06:59 PM   #2
AJA
Re: Reloading clips onto Ki Pro
Steve P. - Yes, you can use the Ki Pro and Ki Pro Mini products for playback. You can move files back onto the units for playback as well. The files transferred to the Ki Pro or Ki Pro Mini must be full raster Apple ProRes 422 (HQ), Apple ProRes 422, Apple ProRes 422 (LT), or Apple ProRes 422 (Proxy) with 24-bit 48kHz audio as either 2 channel or 8 channel.
If you need assistance with this common type of workflow, don't hesitate to contact AJA Technical Support.
Hope this is helpful,
Jon Thorn
Senior Product Manager
AJA Video Systems, Inc.
Currently in Amsterdam at IBC
Jon Thorn is offline   Reply With Quote
Old September 11th, 2011, 02:43 AM   #3
Thanks Jon for the quick reply.
Steve
Steve Phillipps is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
