3 or 4 channel audio? at DVinfo.net
All Things Audio
Old November 28th, 2007, 06:20 PM   #1
Looking for something small and poratable that can take in at least three channels of audio and record it to harddrive or flash/sd card, prefer 4 but three will do, and is there any that also have two outputs to xlr? so I can wire through it to the camera afterwards?
Stephen Eastwood
http://www.StephenEastwood.com
Stephen Eastwood is offline   Reply With Quote
Old November 28th, 2007, 06:53 PM   #2
The two products that come to mind are the Sound Devices 744T and the Edirol R4. Of the two, the Edirol is less expensive and in some ways a better option, particularly if you need to use four phantom powered mics. Both are very good and I've worked with both and honestly give the nod to the R4 (mainly because I hate the interface on the SD 744T, but that's a personal preference and not a technical issue).
Wayne
Mics: KMR 82 i, NTG-1, MKH418S, MKH8040, SR77, QTC1, QTC40, SR30
Recorder: Zaxcom Deva 5.8 & MIX-12. Wireless: TRX900 stereo, Lectro 411
Wayne Brissette is offline   Reply With Quote
Old November 29th, 2007, 04:51 AM   #3
Do you want to record 4 independent tracks or do you want 4 channel input to mix and record as stereo?
Old November 29th, 2007, 01:53 PM   #4
I could go either way, 4 seperate is ideal but 2 or 3 seperate could also work well for me.
Stephen Eastwood
