Sennheiser ME66 / K6 Storage and Stuff... at DVinfo.net
All Things Audio
Old June 25th, 2003, 10:37 PM   #1
Hey All.
Took everyone's advice and bought the Sennheiser ME66 / K6 for my GL2. I do have a few questions on how to care for such a great piece of audio equipment.
1. Should I store it:
a. Fully Assembled
b. Broken Down in 2 pieces
c. With or Without the Battery installed.
d. Does it matter?
2. Do you recommend storing it in it's own foam cut out like the camera or in it's own box?
3. I noticed the little red light flashes ONCE when you Power ON the mic. Does it need to stay solid red?
4. Can anyone explain the little recessed red switch above the power switch?
5. Any additional comments or suggestions?
THANKS!
Aaron Rosen is offline   Reply With Quote
Old June 26th, 2003, 05:02 AM   #2
Gidday Aaron,
This is what I do with mine.....
a/b. Fully assembled with a softie over it. Saves wear and tear on the connector assembly.
*c. With Alkaline battery installed.
d. *If its a long period between uses (months) I would remove the battery just in case it leaks.
2. Mine sits (well floats around) in a Pelican 1620 case next to my DSR-250. With the softie attached it stays in place pretty well.
3. The light should flash 'brightly' at turn on and go out. If it flashes but is dull replace the battery(use a fresh battery to get an idea of how bright it should be).
4. The little red switch is a low frequency or Bass remove switch which you can use to help reduce handling and wind noise - its effect is quite pronounced and can lead to the audio being a little 'tinny' and lacking bottem end. You could probably correct in post if needed. I use mine in the flat position and always have the rycote softie attached to combat the wind noise. The mic is usually on the camera or shock mounted on a stand/boom during use.
Tips:
Remember to turn off the mic after use. It'll run for hours and hours but I seem to have to replace the darn thing just before an event because I forgot to do it at its last outing! (If you can use phantom power from the camera, beachtek adaptor or similar this is not such a big problem).
regards
Jon
Jon McLean is offline   Reply With Quote
Old June 26th, 2003, 07:57 AM   #3
You will find below some pictures of my ME66 protection system including Softie, ME66 and also a DIY case for the mic+cover.
Dany
ME66+ K6 power supply + Rycote Softie 18cm/MH
http://natzo.com/GL2/ME66-11.jpg
ME66 case ... toilet brush holder, hard plastic, cheap
http://natzo.com/GL2/ME66case-01.jpg
http://natzo.com/GL2/ME66case-02.jpg
Fits perfectly the ME66-Softie but too long if mini-mount installed
http://natzo.com/GL2/ME66case-05.jpg
http://natzo.com/GL2/ME66case-06.jpg
Before and after the Dremel correction
http://natzo.com/GL2/ME66case-07.jpg
http://natzo.com/GL2/ME66case-08.jpg
Finally, I can protect the ME66+Softie+Minimount
http://natzo.com/GL2/ME66case-10.jpg
PS: A custom foam has also been cut to receive the mini-mount so the whole mic is protected in the Kata CCC3333.
http://www.natzo.com/GL2/GL2%20in%20CCC3333.JPG
Dany Nativel is offline   Reply With Quote
Old June 26th, 2003, 11:11 PM   #4
I was thinking of storing my ME66 in a long fabric protective bag inside my camera case. Secure and protected from scratches, plus, adds no extra carrying case.
PS - If anyone is interested in a K6P (phantom) powering module, see my post in the classifieds. I need the regular K6 and bought the wrong one by mistake. Thanks.
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Scott Silverman is offline   Reply
