Echo suppression? - Page 2 at DVinfo.net
All Things Audio
Old September 3rd, 2008, 03:18 PM   #16
HI Ty,
You're welcome! Glad to help.
The guys at SPL (at least SPL Germany here in Europe) are pretty cool about test units. While at it, test their DynaMaxx compressor, it is excellent, as are their preamps.
There are a lot more cool units for audio for picture engineers. If you are interested, we could do a little piece about it. I remember your name from way back when, the early audio.rec.pro days I think.
Tingstern,
The unit we are talking about - The SPL Transient Designer 4 - is a 19" rack hardware unit with 4 XLR in and outs. Pure analog hardware, nothing software in it.
I think you are referring to the plugin for the Creamware Pulsar platform. While close, the hardware unit (the 19" analog rack) sounds better. A plugin is always a compromise, an imitation, and in my years experience never reached the quality of the hardware they emulate.
http://www.blakestreetmedia.com
Arthur Kay is offline   Reply With Quote
Old September 3rd, 2008, 03:51 PM   #17
Hello Arthur,
Yes. i'm still hanging on at rec.audio.pro, through some fairly fierce BS, but it's still a valid watering hole if you step over the cow pies.
I reviewed the Dyna Max soon after it came out (I think).
That review and others are up on my online archive. Just for old time sake..
SPL DynaMaxx Model 9735
Ty Ford
Baltimore, Md
The SPL DynaMaxx Model 9735 ($869) is a stereo or two channel
compressor/limiter/de-compressor and gate. In keeping with SPL's tradition of
offering unique solutions for the studio. DynaMaxx provides good sounding gain
control for those who aren't rocket scientists.
The back panel is fairly familiar. There are balanced XLRs and 1/4" TRS
balanced/unbalanced jacks. Both XLR and 1/4" output jacks are hot. The
DynaMaxx also has TRS side chain jacks. There's also a Ground Lift switch, a
120/240 voltage select switch and a standard IEC mains socket. The designers
have obviously spent some time operating table top equipment and short racks,
because each jack on the back panel is labeled so that it can be read upside down
and rightside up. Nice touch.
There are no attack time, ratio, release or threshold knobs; just continuously
variable "Compress" and "Gain" rotary controls (remember the dbx 163?) and a
finely-detented noise gate knob. That means you can't dial in your favorite
settings. Instead you get two controls and two nice looking 20-digit 1dB/LED
ladder meters, one for each of the units two channels. Each channel also has a
small Signal Present LED that lights up when the signal rises above -40dB. There
is no overload indicator. Maximum input level is +24dBu. A Stereo Couple button
links the two channels together allowing control of both from the left channel.
There's also an Active button that operates a relay-operated hardwire bypass. An
illuminated power switch is mounted on the far right of the face of the unit.
The Compress knob sets the amount of compression, incorporating threshold and
ratio. The manual suggests that no peak limiter is unnecessary because, at 50
micro seconds, the transient detection is fast enough top catch the peaks and
automatically re-adjust the attack time. The input and output of the attack
detection circuit are constantly compared. If a transient does get through the first
attack control stage, a second faster stage is activated. The release time is
determined by the difference between the peak and average signal levels. A large
difference creates a faster release time. The manual reveals that a fully clockwise
Compress control yields about a 3:1 ratio.
To compress, start with the Gain and Compress knobs at zero. Turn the
Compress knob clockwise until you start to see a leftward movement of the LED
meters. They will indicate the amount of gain reduction you are applying. The
more compression you apply the lower the level of the audio. The Gain knob
controls makeup gain, so for every adjustment of the Compress knob, you have to
reset the Gain knob. The Gain knob is calibrated to the LED display, so that the
lighted part of the display moves to the right end of the display as makeup gain is
added. Basically, the Gain control lets you set the proper input level to whatever
the DynaMaxx is feeding.
To get an idea of the amount of gain reduction for a particular setting, I stopped
the music and waited for the LED to come to rest. In one case it stopped at +6dB,
which was where I had the Gain knob set. With the music on, the display pushed
to the left and ranged between -2dB and +2dB. That meant a gain reduction of
somewhere between 4dB and 8dB. The meter goes from -10dB to +8db, implying
the possibility of up to 18dB of gain reduction.
The Soft Limit mode is much more sensitive to peaks. When I kicked in the Soft
Limit switch using the same music, the display started showing a gain reduction
range from +6dB down to -10dB (16dB), with a noticeable compaction of sound.
When I reduced the Compress Setting (from 6 to 5), the track got louder so I
reduced the gain from 6 to 3. With Soft Limit in I was now seeing gain reduction
excursions from a baseline of +3dB down to -6dB, a total of 9dB of gain reduction.
Further experiments with some studio recordings of a Yamaha grand piano
yielded similar results. With Soft Limit In, I could hear some "crunch" and a bit
of pumping at some of the more percussive moments. Without Soft Limit, the
piano just sounded tight.
The Effect Compression button sets the compressor release time to 60ms, allowing
for some grungier settings, but I found that more aggressive settings were
possible with Soft Limit. The Noise Gate is rather ticklish. With or without
compression, even in a quiet studio, the gate fluttered quite a bit, opened abruptly
with a small noise each time it opened. If you're gating loud sound sources with
percussive attacks, you won't run into this problem.
Recording bare voice tracks with moderate amounts of gain reduction caused the
compressor to pull up some noise at the ends of paragraphs, but the effect was
hardly noticeable within sentences and phrases. The Noise Gate and was too slow
to open or close for spoken word recording. I could never find a setting that didn't
clip off the first moment of sound or pop open unexpectedly. Music with longer
decay trails and more continuous tones fared a lot better.
ACcentUate the poSitive
In addition to its unconventional approach to compression, the DynaMaxx also
de-compresses in a way that makes any sound that crosses the threshold jump
out even louder. Use the Soft Limit circuit and the sound jumps out even more.
This is a new subjective area for you to wander around in. I put some recordings
from the new Larksong madrigals Xmas CD I'm just finishing and set the
threshold for the early part of a verse. When the group hit the chorus they got a bit
louder, crossed the threshold and got bumped up in volume. The effect sounded
uneven and jerky. Taking Soft Limit out smoothed things out. I popped in the
amazingly compressed KIX "Hotwire" CD and found it was so compressed that
setting the de-compress control was a bit difficult because the mix was so dense
and compressed. In the verses and solo break where the tracks were less dense,
the kick drum popped out above the mix. On the chorus, where everything was
turned up to eleven, the wall of guitars jumped out followed by everything else.
The manual suggests using the de-compressor on samples that have been overly
squished and on other sources. I can hear it being used on soloed parts more than
I can on a full mix.
The manual spends a noticeable amount of words in praise of the THAT 2181
VCA chips used in the DynaMaxx; offering that they are responsible for the lack
of dulling of the processed sound and reduced distortion and noise. No question
about it. The DynaMaxx does seem to exhibit less destructive "crunching". If
you've become addicted to dynamic range control byproducts, you'll probably end
up using the Soft Limit and Effect Compress all the time.
Although the DynaMaxx can be used on individual inputs or tracks, it should also
do well hung across the main two-mix ouput of a console to give raw sounds a
more polished surface. For loading into workstations, you can use DynaMaxx to
bring the audio right up to Digital Zero without mangling the sound. Because of
its ease of operation, it's also a very good choice for people with limited audio
experience who are processing audio for the Internet.
Several words of caution for anyone starting to use compression; use less than you
think you need. It's always better to crunch more later than to over-crunch. Also,
as with many compressers the DynaMaxx will suck up the noise floor with low or
no audio present. For example, the space between the opening chords of the
Rolling Stones' "Start Me Up" was large enough to make the DynaMaxx reach
down for the analog noise at the bottom of the CD track. It did this with 8dB of gain
reduction with Soft Limit IN and Effect Compress IN or OUT. The Noise gate was
simply not fast enough to close down gracefully between the guitar chops.
IN CONCLUSION
If you can get past the idea of not having all the control parameters to play with,
there is value to a gain reduction device that can provide somewhere around 18dB
of gain reduction in Soft Limit Mode without dulling or ducking or pumping, and
get a bit nasty sounding as well.
Application: single, dual channel or stereo, analog, dynamic range control
Plus: easy to use, flexible I/O interface
Minus: somewhat slow and jittery noise gate, slightly more expensive.
Regards,
Ty
Ty Ford is offline   Reply
