ME - 66 Popping Noise....??? at DVinfo.net
All Things Audio
Old October 20th, 2003, 10:07 AM   #1
My shotgun Mic will make a random crackling and popping noise. We thought it could be because it was picking up something we couldn't see, but we think it might be the mic. Any one have this problem or have a suggestion???
Cb - philly
Christian Bovine is offline   Reply With Quote
Old October 20th, 2003, 03:51 PM   #2
Is the mic connected to a phantom power source? If so, random noises like that suggest an imbalance in the phantom voltage reaching the mic, usually due to a bad cable.
Jay Massengill is offline   Reply With Quote
Old October 20th, 2003, 06:51 PM   #3
You need to troubleshoot that to isolate the problem.
First change cables and see if that kills the pops.
Try another microphone with the original cable and see if that kills the pops.
Try another camcorder with everything else original and see if that kills the pops.
Try a new battery in the microphone and see if that kills the pops.
Individually change each piece in the audio chain until the problems goes away.
Cables are always the first suspect.
Mike Rehmus
Old October 20th, 2003, 09:47 PM   #4
Is it shock-mounted? It is an ultra sensitive mic and if mounted on a camcorder or boom, shock-mounting is not optional it's a must.
Marty Wein is offline   Reply
