sound advice for narrative at DVinfo.net
All Things Audio
Old August 17th, 2009, 03:50 PM   #1
anybody know best way to emulate voices through a thin room wall? and a telephone voice?
thanks
A
Amos Kim is offline   Reply With Quote
Old August 18th, 2009, 06:22 AM   #2
Try Speakerphone 2.
Old August 18th, 2009, 07:29 AM   #3
In Vegas its easy.
Click the audio fx, then track EQ.
Click preset... and make your choice. Telephone is there.. Its simply 15db gain at 928Khz, while all before and after are at a gain of minus infinity. (A notch filter at 1Khz)
Thin walls would be to knock off the treble above 2Khz... play with it and see, er, listen.
I dont know about other NLEs... anyone?
Ben Longden is offline   Reply With Quote
Old August 18th, 2009, 08:34 AM   #4
The best, most realistic way is to use a Convolution plug-in with an impulse sample. Essentially the impulse sample records the acoustical characteristics of a room or electronic device. There are some free plug-ins available.
For the PC there is SIR - SIR: SIR1
For Mac Tconvolution - Tconvolution v0.51 for Macintosh OS X
Then you have to find impulse samples that match what you're trying to emulate. There are sources for free impulse samples on the web. Here is a good directory of sources:
KVR :: View topic - free Impulse Responses
Brett Sherman is offline   Reply
