Proper technique when using the 442 with a 744T and an HVX at DVinfo.net
All Things Audio
Old September 3rd, 2009, 02:49 PM   #1
Hello all!
I'm a mixer in Calgary, AB and I'm looking for a little advice about a setup that I'm planning to use for an upcoming short film. I've convinced the producer to use dual system sound, but I want them to have something to listen to in the rough edit so I was going to also sent a 2 ch mix to the HVX. Anyway, here's how I think it'll go:
- Inputs: 1=boom/2, 3, 4=lavs
- Direct Outputs 1-4 going to the 744t
- 10 pin output back to the HVX w/ headphone return
Will that sound good and be usable in post? I haven't done 4 channel before, so this is new to me. Any help you guys can give would be appreciated.
P.S. One totally off topic question: is there a reason not to enable output limiters on the 442?
Alex Mitchell is offline   Reply With Quote
Old September 3rd, 2009, 07:28 PM   #2
Originally Posted by Alex Mitchell View Post
Hello all!
Setup is good.. keep the limiters on.
Jeffery Magat is offline   Reply With Quote
Old September 8th, 2009, 09:58 PM   #3
You may want to send timecode to one audio channel on the hvx to make it easier for post to sync.
www.marshallstaton.com
Marshall Staton is offline   Reply
