#16 |
Prefade is extremely useful when multi-tracking.. 4, 8, 16+ tracks, music for instance, however with just two tracks, except in a mix-minus type instance. If it's switchable, I'm sure it would come in handy at some point.
I'm seeing used 442s on RAMPs and ebay for $1800-2000usd. I expect the price to drop once the 552 is actually available. |
#17 |
Hybrid
Looking at the 552, I reckon in the next few years they will merge the mixers and recorders together, so you have the mixing power of the 552 but with the recording potential of the 744/788
They could afford to some some of the outputs as they woldnt be necessary but sitll many for monitors comtek etc now that would be brillint! |
#18 |
I recently spoke with a tech from SD the day after I heard about the 552. He mentioned exactly that.. they will be and are working on ways of merging the "full" functionality of the recorders with the mixers. The 552 is a good step in that direction, but obviously it's for someone that has the need for a mixer more than a dedicated recorder. The biggest thing of the 552 to me is the optional pre/post fade direct outs... wow huge.
I currently use a PSC promix6, and I'm about to have it modded to have 4 of 6 direct outs changed to post fade and leave 2 for pre since they can't physically get a pre/post toggle switch on the unit.
www.soundgeekproductions.com |
#19 |
A cheaper alternative to the 552 would be the Marenius MM-4220, it only has four channels but it’s half the price.
#20 | |
Connectors on the back is weird, not suitable to be carried in audio bag for cable in and out on the side.
Got 3 'S': Schoeps, Sound Devices, and Sony. |
#21 |
Yes, the spec. is a little bit better on the 552. Maybe the 96 kHz sampling frequency is one of the major reason for buying the 552, but is it worth a doubled price? However I don't agree with the cables on the back since PortaBrace makes excellent cases for this purpose.
#22 |
Which mixer, sd 302 or SQN 4s 3a
Hey guys this is unrelated but some of my fave people are in here, and for some reason I cant start a thread.... which mixer should I go for?
The 302, has input and output limiters, 2 stage gain, upto +20dbu meter, tone and slate, 2 XLR out, VU/Dbu meter is color coded for line and peak, but shows the entire headroom too Is roughly about 5 years old. The SQN has 1 channel extra, only one stage gain but attenuator from -10, -20, no input limiters but 40:1 output limiters, 2xlr output and 10pin hirose, could be upto 15 years old PPM meter means you mix to broadcast standards, but does not register the headroom after. It doesnt have a slate mic. They both have the same panning and hi pass options. Tough call opinions welcomed!!!!! Leeut\ |
