making XLR cables tips - Page 3 at DVinfo.net
All Things Audio
Old March 6th, 2006, 02:41 AM   #31
Hi Glenn,
Regards
Leigh
Leigh Wanstead is offline   Reply With Quote
Old March 6th, 2006, 06:40 AM   #32
Originally Posted by Glenn Davidson
Radio Shack and Markertek sell a "Dual Helping Hand" which is two alligator clips on a heavy base that works great for holding the work. Also, I use a small fan to blow that toxic smoke away from my face.
Toxic smoke???
I love the smell of rosin vapours in the morning! It smells .... electric! <grin>
Old March 6th, 2006, 08:09 AM   #33
If you are going to be making custom lengths or are going to be doing a whoile studio, it might pay to get a good crimp tool and go with something like VM-2000 cable from Gepco. It is super cheap to make your own, IF you have a crimp tool for the specific cable and connector set.
Cable is in the range of 20 cents per foot in bulk wholesale. Usually that means buying 1000' of cable. Connectors are between $1.00 and $2.50 depending on type and manufacturer. Still, if you consider 2 BNC connectors and 100' of cable, that's only $25 for some good, flexible, high quality cable.
The great thing is, if you need custom lengths, you just make them. Makes for pretty rack installations if you can make custome lengths, and helps cut line losses if you don't have that extra 20' coiled up on the rack room floor.
Sean McHenry
‘I don’t know what I’m doing, and I’m shooting on D.V.’
- my hero - David Lynch
http://www.DeepBlueEdit.com
Sean McHenry is offline   Reply With Quote
Old March 6th, 2006, 11:36 AM   #34
Hi Sean,
Thanks for the information.
Regards
Leigh
Old March 6th, 2006, 11:54 AM   #35
I am very confused. There are so many choices.
Here is the link.
Click here
Which one to select even for the same brand Canare Cable?
TIA
Regards
Leigh
www.markertek.com sells Canare Cable.
Old March 6th, 2006, 11:56 AM   #36
If this is for mobile or general work, just use their standard 2 conductor. It's tough, easy to solder, and is a very good/solid cable.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 6th, 2006, 11:59 AM   #37
Hi Sean,
I don't do a whole studio. I make stabilizer and I want to record some introduction video of my stabilizer by my dad hold a boom with a Audio-Technica AT4073 shotgun microphone and I do the all talking. I will use some zoom shot and wide angle shot. What cable length do you think I should buy?
TIA
Regards
Leigh
Sean McHenry
Old March 7th, 2006, 12:49 PM   #38
A good "short" length for field use in small spaces is probably about 25' (8.5 meters).
Old March 7th, 2006, 02:11 PM   #39
Hi Seth,
Thanks for the answer. ;-)
Regards
Leigh
