Audio XLR "Y" & "Z" cables at DVinfo.net
All Things Audio
Old January 27th, 2010, 02:07 AM   #1
I was recently asked to make a "Y" cable... Male XLR to 2 Female XLR's to be used on the camera so 2 microphones could be combined into 1 of the cameras inputs.
Now while technically possible it needs to be noted that doing it this way the background noise will increase and it gives NO control of individual microphone levels, and should NOT be used for critical audio recording. This is where mixers come into their own giving control of levels and dropping unused microphones.
I have two "Z" cables (2 Male & 2 Female XLR's in a Z configuration) in my kit I find them much more useful as they can be used as a Combine, Split, M-M or F-F cable.
Last edited by Brian P. Reynolds; January 27th, 2010 at 02:14 AM. Reason: to clarify a point
Brian P. Reynolds is offline   Reply With Quote
Old January 27th, 2010, 04:07 AM   #2
You can have difficulties combining two mics with a simply Y cable as they can interact with each other. Far better to use a simple mic combiner with a transformer that isolates the 2 mics from each other. An example is this one from Whirlwind .. Whirlwind / Combiners
Steve House is offline   Reply
