H4N firmware update that enables... - Page 2 at DVinfo.net
All Things Audio
Old December 15th, 2010, 05:44 PM   #16
Note that this update only affects the INPUTS, as noited in the first post, not the onboard mics, whose levels are still ganged together. Still a very nice update.
Old December 31st, 2010, 12:48 PM   #17
H4n Recorder Firmware update issue
I have the same problem.I updated to firmware 1.7 and everything seamed normal,but when i go to the menu,some of the feature are gone.I can't find the mode button,and others.i can't switch to mp3 or wave,and i can't switch to 4 channels or MTR mode.How do you restore this thing?
luciano
Luciano Alexandresco is offline   Reply With Quote
Old December 31st, 2010, 04:01 PM   #18
Same problem
I'm having a similar problem too. I followed directions just like it said, but it doesn't give me the added feature it says it would. Also, what is this about turning the power on with play/pause button???? That doesn't work!!!
Russ Ivey is offline   Reply With Quote
Old December 31st, 2010, 04:54 PM   #19
Are you sure you read that correctly?
How to update the system software
4) Then turn power on while holding down the [PLAY/PAUSE] key.
5) Move the cursor to “OK” by using the [DIAL].
6) Push the [DIAL] to start the system update.
You omitted the "while holding down" bit.
Old December 31st, 2010, 09:13 PM   #20
Originally Posted by Manuel Coronado View Post
I'm having issues with the firmware upgrade. Successfully installed it. Now I cant change it from Stereo to 4CH. It appears like that option was deleted from the menu. Searched everywhere and cant find it. Was wondering if anyone else was having that issue. Is there somewhere where I can download a previous version of the firmware? Thanks.
If your unit has stamina switched on, you can't access the 4 ch. Turn the stamina off.
Old January 1st, 2011, 01:05 PM   #21
Problem solved
Warren,turning stamina off worked.It seamed that with the 1.6 firmware,before i updated,this menu showed with the stamina mode on.But i might be wrong!:-)
Thanks for your help!
luciano
Old January 1st, 2011, 04:21 PM   #22
I held it down Colin for several seconds. It doesn't turn the device on.
Old January 1st, 2011, 04:56 PM   #23
Russ,
To put it another way....
1. Press and hold the PLAY/PAUSE button.
2. Actuate the power slide switch.
3. Once the unit turns on, release the PLAY/PAUSE button and power switch.
Old January 2nd, 2011, 06:46 PM   #24
Mark
Thanks Mark!! That was exactly what I needed. It rebooted and everything is working fine now.
