#16 |
Guy,
You will want to run Magic Lantern. Canon's audio code boosts the analog signal by +31 dB and all control is done by reducing the digital gain. I believe that they did this because it provides simple monotonic gain control. A better solution would have been to ping pong between analog and digital gain, but they would have risked strange gain changes between certain tick marks. With Magic Lantern, you can set Analog Gain (m-gain) to +10 or +17dB and Digital Gain (d-gain left and right) to 0 dB for excellent results. The one bummer about recording into the 5D2 is that it has a high pass filter always enabled. This is no problem for dialog, but isn't ideal for music.
Jon Fairhurst |
#17 | |
DVCreators.Net
#18 |
Thanks for the offer! Unfortunately, I'm overly busy for the next few weeks. Otherwise, I'd take you up on it!
Jon Fairhurst |
#19 |
So other than the technical jargon, when will it be released?
#20 | ||
DVCreators.Net
Another thing worth noting is that the short cabling of the new VideoMic Pro is high quality Mogami cable. Nice touch. Anyone know of a source for a super high quality 1/8" mini extension cable? With the original VideoMic, I tested an unshielded 20' Radio Shack cable and got buzz. With the VXLR (3.5mm to XLR adapter) and a BeachTek, it all went away. The VideoMic Pro on a boom pole is going to surprise a lot of people. I'm looking for a cable to do a few more tests to put up a video showing the VMP on a boom pole if anyone is interested in hearing it. |
#21 |
"Anyone know of a source for a super high quality 1/8" mini extension cable?
Just so happens I re-did my bag two months ago. I used Canare "L-2E5 mini microphone cable" and "L-4E5C mini star-quad". For any 1/8" plugs I used Neutrik NT3RC (right-angle) and TecNec M3.5S locking. |
#22 |
I use the Rode VC1 cable. It's a bit on the short side for booming (10 feet), but that limitation is better than buzz/noise.
Tascam DR-40 vs. Zoom H4n |
#23 |
My above post was making y'own.
Markertek, Trew, Gotham, Dale, ect. would gladly make cables using the same or other premium components. Big box stores like B&H do not make cables. And if they they have a specific cable, it will likely be mass-produced w/molded plugs and low-cost cable stock... which may be fine, for occasional usage and in a 'perfect world'. |
#24 |
Guy not to jump off topic too much but wouldn't the 3,5mm to XLR adapter and XLR extension cut out the buzz too if any. I've had great luck running 1/8" extensions but wonder if the 3,5mm to XLR adapter would mitigate the problem.
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom |
#25 |
I wish it had an XLR plug for my ENG camera, then I would be interested.
I don't believe in using adaptors, especially on-camera. Patrick McLoad |
#26 | |||
DVCreators.Net
My boom pole (K-TEK KE110CC) is the coiled cable type so the XLR is built-into the pole. I have slapped a RODE VXLR on the RODE VideoMic Pro for me it works great as once it goes to XLR, it is balanced, but I'm trying to help folks that are just going to mount the mic on a stand or in a fixed position close to the subject. Quote:
I think this mic is geared towards folks that want to put it on camera, but as all audio professionals know, the key to really great sound is to get the mic close to the subject. So, I think that the VideoMic Pro is going to appeal to those that know that they're going to get "ok" sound with it on camera, and then I'd like to see more people getting used to the idea of improving sound quality by using the VMP with an extension cable on a pistol grip, stand or on a boom pole. I know a lot of us want to use the best gear with proper XLR mic + cable, adapter/mixer, recorder, but sometimes getting 90% there for 1/4 of the cost is "good enough" for general use. We all have different clients with different degrees of what is perceived as acceptable audio, and we all have different budgets. This VMP fits a nice little niche of, getting us that much closer to great sounding audio. Heck, maybe that's the video clip I need to put together, this is the VideoMic Pro, from 10 feet, 5 feet, 2 feet. This is the NTG-3 into a mixer, into a recorder at same distances. Then ask the question, "Is this better sound worth the extra cost to you?" |
#27 |
"Heck, maybe that's the video clip I need to put together, this is the VideoMic Pro, from 10 feet, 5 feet, 2 feet. This is the NTG-3 into a mixer, into a recorder at same distances. Then ask the question, "Is this better sound worth the extra cost to you?"
Great idea Guy. If you don't do that, I will after I get my own VMP.
My Work: http://www.youtube.com/ChadWork1 Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3, |
#28 |
Thanks for the recommendation Guy; I'll take a look at the Audio Technica AT875R. Yes, the price is right, though hate to loose the stereo feature of the Sony mic, for what that's really worth.
Patrick McLoad |
#29 | ||
DVCreators.Net
Option 2, and what I would do, Sony has some b-stock ECM680s stereo shotguns - these sound pretty amazing for $574.85. These are normally $900. Sony Pro Outlet Product List And last but not least...for those that would like to see a size comparison....here is the original RODE VideoMic, the RODE VideoMic Pro and the Sennheiser MKE400. |
#30 |
For a budget stereo on-cam mic, try the Beyer MCE72. I used to have one and found it pretty good for getting good "ambient" noise, a good, general all-round mic - it used to live on my Sony V1E until I sold the complete package.
Cost is around $300: http://www.bhphotovideo.com/c/product/290399-REG/Beyerdynamic_465461_MCE72_Portable_Stereo.html |
