lavalier sanken cos 11 to be plugged to mini jack trs for ew 100 g2 at DVinfo.net
All Things Audio
Old September 11th, 2011, 04:07 AM   #1
how do I have to plug a sanken cos 11 to mini trs plug for sennheiser ew 100 G2,
hot (2) on tip, cold (3) on ring and earth (3) on shield, does it work CONSIDERING THAT G2 IS unbalnced and connection for micro on sennhieser manual are tip to hot and cold and earth to shield,
David Aliperti is offline   Reply With Quote
Old September 11th, 2011, 05:08 AM   #2
Re: lavalier sanken cos 11 to be plugged to mini jack trs for ew 100 g2
In the G2 the ring is not connected (it's the line-in connector) for the mic. input.
In the G3 the ring needs to be shorted to sleeve.
The mic. should be connected to tip and sleeve only.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old September 11th, 2011, 07:49 AM   #3
We need to know what connector is already on your Sanken lav? From your message it sound likes you have the XLR Power Supply model designed for hard-wired use with phantom power but that's just an inference. What do you actually have?
Old September 11th, 2011, 08:07 AM   #4
sorry, i have to plug it to trs mini, to be plugged in ew100 g2 transmitter
Old September 11th, 2011, 08:46 AM   #5
That's not what I asked. I know you need to connect to a TRS miniplug. What we need to know is what connector is on the mic cable now, not what you need to adapt it to. Or is it just bare wires? If it's bare wires, try this diagram from the Sanken web site ... http://www.sanken-mic.com/en/qanda/index.cfm/11.25 (3-wire) or http://www.sanken-mic.com/en/qanda/index.cfm/20.73 (2-wire). The general wiring sheme is shown here ... http://www.sanken-mic.com/en/qanda/index.cfm/4.19
Steve House is offline   Reply
