Tetra Mic from Core Sound at DVinfo.net
All Things Audio
Old October 10th, 2013, 12:41 PM   #1
Has anyone used this tetra mic from Core sound? Core Sound — TetraMic
How good or bad is the quality? Look forward to hear your views.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old October 13th, 2013, 05:58 PM   #2
Re: Tetra Mic from Core Sound
There is an extensive discussion about the Tetra Mic (including participation from Len Moskowitz from Core Sound) over on GearSlutz
Tetramic? - Gearslutz.com
Richard Crowley is offline   Reply With Quote
Old October 27th, 2013, 11:07 PM   #3
Thanks Richard!
That link has got tons of information.
Old October 28th, 2013, 03:34 AM   #4
Basically a copy of the design of the (calrec) soundfield mic: SoundField: The Company
So it should give similar results but at a lot lower cost !
Old October 30th, 2013, 07:19 AM   #5
But the Soundfield uses true condenser capsules and the Tetra uses unbalanced electrets.
And there is the new "Brahma" coming soon, which will be even cheaper - looks interesting.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old October 30th, 2013, 09:34 AM   #6
All condenser mic capsules (externally charged AND electret) are "unbalanced" by nature.
And some of the highest-regarded microphones on the planet are electret (e.g. DPA)
Now it is quite possible (probable?) that the Tetra capsules and circuitry are of lower quality than the ones
Calrec uses, but that is likely the case with most any kind of product that is available in several price ranges.
Old October 31st, 2013, 04:27 AM   #7
Yes and no.
An RF condenser mic. *is* balanced by nature.
Although an AF condenser is an unbalanced capsule, it is balanced inside the housing of the microphone and exits the microphone as a fully balanced signal.
The Tetramike exits the microphone on an unbalanced cable and is, as far as I am aware, only gets balanced at the XLRs at the end of the cable.
Oh - Calrec have had no involvement with the Soundfield microphone for decades - they sold it to AMS who then sold it to Ken Giles (Soundfield) who retired last year and sold the company to TSL in Marlow.
The Soundfield capsules are OEM supplied by MBHO in Germany, who have a quality equivalent to that of Schoeps.
Old October 31st, 2013, 10:54 AM   #8
"T]he Tetramike exits the microphone on an unbalanced cable and is, as far as I am aware, only gets balanced at the XLRs at the end of the cable."
This is the case for most lavaliere mics as well.
Old November 2nd, 2013, 07:14 AM   #9
Originally Posted by Rick Reineke View Post
"The Tetramike exits the microphone on an unbalanced cable and is, as far as I am aware, only gets balanced at the XLRs at the end of the cable."
Yes - but most professional microphones are fully balanced from the output of the microphone.
It's only consumer microphones and electret tie microphones & headmics that run unbalanced down a cable.
Running unbalanced down a cable increases the risk of RF interference, especially when the cable length gets close to the frequency of the RF interference.
Old November 2nd, 2013, 09:08 AM   #10
That's what I was stating. "electret tie microphones (aka, lavalieres) & headmics"
Furthermore, most lavs that have 3 wires, the 'third' wire is for bias current (power).. from a transmitter, in-line battery or XLR Phantom Power adapter.
Old November 2nd, 2013, 09:13 AM   #11
Note that "the output of the microphone" may not be the microphone head itself.
And some "professional microphones" do not have true differential-balanced output, but are actually single-ended and are just "impedance balanced" with a 5-cent resistor.
Many professional condenser microphones run unbalanced audio between the microphone head and the power supply box where the output transformer is located. A run of unbalanced audio is not an indication of "cheap" or "low-end". The unbalanced audio is typically cathode-follower and relatively low impedance. Modern electret capsules have impedance conversion circuits inside the capsule which is a modern equivalent of that classic circuit design.
Not just RF interference. In fact, probably even MORE susceptible to in-band interference.RF interference can be easily filtered, but in-band cannot.
