Rode Invisilav & Sanken COS-11 at DVinfo.net
All Things Audio
Old March 29th, 2014, 11:22 AM   #1
Has anyone tried if the RODE Invisilav is compatible with the Sanken COS 11D?
Firewerkz Films SGP
Old March 30th, 2014, 11:00 AM   #2
Re: Rode Invisilav & Sanken COS-11
I'm sorry, but what? That's like asking if a Sony camera is compatible with Canon camera. What are you asking?
Victor Nguyen is offline   Reply With Quote
Old March 30th, 2014, 11:59 AM   #3
It appears it may.. but without the specs, who knows.
Old March 30th, 2014, 05:03 PM   #4
ah, I get what you're asking now. What's wrong with transpore tape if you want it to be clear. If you want a mounting rubber then there are RM11.
Old June 9th, 2014, 05:35 PM   #5
I bought some to try out. The COS11 is a little bit loose but the real problem I had was I couldn't get the included double sided mounting tape to stick to it. I also tried cleaning the mount with Alco wipes before applying Topstick, but even gaff wouldn't stick. Maybe if I roughed up one side of it with fine sandpaper??
Andrew Hogan is offline   Reply With Quote
Old June 13th, 2014, 12:35 PM   #6
I use the Sanken RM11 with both Rode lavalier and Sanken cos11d mics. It seems much better designed than the invisilav... the vast majority of the time you are only using a single microphone so why use something larger than needed; the larger the profile the more likely you will get clothing rub.
I find that top-stick adheres well, but I prefer to use Joe's sticky stuff because it's easier to remove. I usually cover the whole thing with moleskin to further hold it in place, but still add the Joe's sticky stuff underneath in order to reduce rubbing against the skin.
Tom Morrow is offline   Reply With Quote
Old June 14th, 2014, 07:09 PM   #7
We have limited access to moleskin here. Will check it out!
Firewerkz Films SGP
Sean Seah is offline   Reply
