Fitting mains input plug to Sennheiser NT1-1 at DVinfo.net
All Things Audio
Old April 8th, 2014, 03:22 AM   #1
Hi Guys
Have got a 3 pin mains input plug to attach to a Sennheiser NT1-1 charger. However, there appear to be two small bits of black plastic on the rear of the plug (just above the 'U' where it says U.S. Pat. No. and just above the 'D' where it says D.B. Pat. Nr.) that block the insertion off the green and silver connectors on the charger. Have tried pushing down on the 2 bits of black plastic with a piece of cardboard to see if they drop down, but they seem firmly in place. As a result, I am afraid to press these two firm bits of plastic down on the green and silver connectors for fear of damaging the green and silver connectors.
Is the 3 pin mains input plug defective by having these two small bits of black plastic instead of two little holes that the green and silver connectors could slide into, or should I be using force to push the plug down on the green and silver connectors?
The green and silver connectors and plug holes can be seen in the 2nd and 3rd pictures at:
http://www.thomann.de/gb/sennheiser_nt11.htm
Warm regards
Peter Dunphy is offline   Reply With Quote
Old April 8th, 2014, 05:53 AM   #2
Re: Fitting mains input plug to Sennheiser NT1-1
I presume the UK plug came with the PSU - if so, it should just slot on.
If you bought this separately, then it could be one for a different PSU.
I suggest you ring Sennheiser UK Service Dept. and discuss with Sam Davison, the Service Dept. Supervisor.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old April 8th, 2014, 06:58 AM   #3
Thanks John, appreciate it.
Yeah the plug came with NT1 power supply (same box) and unfortunately doesn't slot on.
Old April 9th, 2014, 02:36 AM   #4
Phew, with a little pressure the 2 little plastic bits that blocked the connectors slid aside. Thanks for your input John.
