#16 |
Re: Audio improvement help
I am using the "Creative Cloud" subscription version of the Adobe applications.
I don't know which version of Audition you are using, but the basic functionality is the same. Simply drag that "4" spot over to somewhere around 3600 Hz and down ~12dB And the "H" spot over on the right end controls the low-pass (high-cut) filter as I described. You can simple mouse-over and drag those filter spots around and hear what they sound like. VST is a standard for using plug-ins from different vendors. Apparently Adobe uses the VST standard even for its own built-in filters.. For the purposes of this discussion, it has no significance. |
#17 | |
I also use the CC version of Adobe Audition and don't have the same parametric EQ but it doesn't matter. I did what you suggested and it sounds very muffled to me. I listened on two different sets of headphones (Sennheiser HD 280 Pro and Sennheiser HD 800). I think I need to add some frequencies back in now. https://www.dropbox.com/s/afzzbx3z1t...d4_01.wav?dl=0 |
#18 | |
It is poor technique to remove something that you will subsequently restore in a subsequent step. It is guaranteed to inflict audible trauma to your track. PLEASE do not post hour-long samples!!! 30-60 seconds of an appropriate section will be MORE than enough for anyone to hear what you are talking about. |
#19 |
Equal Opportunity Offender
I've got RX4 Adbanced with a set of Event 2020 monitoring speakers.
I've done a couple of passes of broadband noise reduction and this in turn shows up the 'artificial fuzz' that I'm guessing is possibly the result of a low quality process that has been applied to your original file at some stage, possibly in the way you got it out of the recording gear. I've tried some "dereverb" (aka echo removal) and a stiff application of this has really helped. There is still problems with the audio that remains. It's just not going to be the perfectly usable recording that you would want. If you have the advanced version of RX4, you can grab the text file that I have uploaded, rename to a .xml extension type, and then import this in to Izotope RX4 and see what I mean. To be honest, I'm not sure how you are going to be able to satisfactorily fix this one. You might want to have another crack at getting the audio off the recording equipment exactly as it was recorded in case this makes a difference. Andrew |
#20 |
Do you have a good recording of this same person?
#21 | |
#22 | |
#23 |
#24 | |
Why are we otherwise doing all this messing around here??? Andrew |
#25 | |
There is no "good copy of the recording". Unless you are implying that they re-record the whole thing? The poor tonal balance could be significantly improved by judicious use of a parametric equalizer and I was trying to show how to do it. However it does seem pretty resistant to getting decent balance out of it. |
#26 |
I thought she was indicating that there was a better quality of the audio that she could go and get. We might need to wait for clarification from her on that one.
Andrew |
#27 |
I thought Gary asked if I had any voice recording of this person. I thought he wanted to compare it or something like that. I don't have a second recording of the interview and I can't redo it
#28 |
Ahh. I see.
All the best with making the most of what you have. Andrew |
#29 |
I (Greg, not Gary) understand that this is the only recording of this interview. I want to know whether you have any other good recording of this same person's voice.
#30 |
Sorry GREG. I do not have any other recording of the person but I can get it. Should it be from the same location?
