Syncing Audio - Page 2 at DVinfo.net
All Things Audio
Old August 4th, 2015, 05:19 PM   #16
Re: Syncing Audio
Originally Posted by Dean Sensui View Post
FCP-X will easily sync multiple sources. As you said, one of the audio tracks is out by 3 frames, and that will create an "offset" for that track.
Otherwise, the sync (using audio as a guide) is quite precise.
I'm new to fcpx so I can't rule out user error but it wouldn't sync anything. Where as pluraleyes versions 1 partially synced them in fcp6. I was also testing pluraleyes 3. That worked the best but wouldn't import into fcp6 got a xml error. This might be because upgrading to Yosemite broke xml. I see that newer has an audio replace feature ppl were talking about.
Old August 4th, 2015, 06:21 PM   #17
Re: Syncing Audio
I synced a GoPro with audio from a small recorder on a boat and was amazed that FCP-X was able to sync all six clips despite the sound of the engine and the usual muted audio of an encased GoPro.
I posted this elsewhere on the forum, but here's the result with one of the clips.
Dean Sensui
Old August 5th, 2015, 11:20 AM   #18
Re: Syncing Audio
This is totally OT, but.......If I found a life preserver in open water I would have spent at least a few minutes looking around the area to see if anything else was floating nearby. You obviously assumed it blew out of a boat which it probably did....but hey, it IS a life preserver.
Steve
www.CorporateShow.com
Old August 5th, 2015, 12:50 PM   #19
Re: Syncing Audio
We did look. And I radioed it in to the USCG, too.
Steve
Dean Sensui
Old August 5th, 2015, 12:57 PM   #20
Re: Syncing Audio
In this business you either sink or swim. ;-)
Old August 5th, 2015, 04:53 PM   #21
Re: Syncing Audio
You mean sync or swim? :-)
Dean Sensui
Old August 5th, 2015, 07:05 PM   #22
Re: Syncing Audio
Sync or sink.
Old August 5th, 2015, 07:10 PM   #23
Re: Syncing Audio
Lol
I had to stop playing around with trying to do a sync multiclip so I could get this out.
Old August 7th, 2015, 09:41 AM   #24
Re: Syncing Audio
I figured things:
1. Using Fcp6 I extracted the board/shotgun audio from the primary camera movie and exported a stereo pair audio file for each.
2. After I entered the clips angle field fcpx synced it (missed this step before).
In the timeline I used the extracted audio in the previous step, enabling me adjust/mix the ambient and board feed independently.
I really love how fcpx audio level adjustment works. Color of the wave form indicates problem areas and selecting range tool creates the keyframes automatically. So much quicker.
Pete Cofrancesco is offline   Reply
