walkie talkies at DVinfo.net
All Things Audio
Old November 10th, 2005, 05:15 PM   #1
walkie talkies
I am looking for a set of walkies talkies so i can keep in contact with the 2nd cameraman in events i do.
could you guys pls suggestion som models with headsets?
i have only found one and it costs like $400 way too much!
Dan Farzad is offline   Reply With Quote
Old November 10th, 2005, 05:37 PM   #2
A couple years ago we bought 9 Motorola CP-100 radios for around $240 each. They have held up to a lot of abuse backstage.
http://www.motorola.com/governmentan...2352i/id_1663i
There are plenty of less expensive FRS radios out there if you need something cheap. These work very well, considering the cost, but since they aren't licensed you often get others cutting into your conversations.You can get them anywhere, like big box electronics or dept stores.
See some other threads on this topic:
http://www.dvinfo.net/conf/showthread.php?t=44678
http://www.dvinfo.net/conf/showthread.php?t=14710
http://www.dvinfo.net/conf/showthread.php?t=9539
