Shock mount from K-Tek - Page 2 at DVinfo.net
All Things Audio
Old December 12th, 2005, 03:00 PM   #16
Originally Posted by Marco Leavitt
I'm pretty sure you do. This is from the features page for the Mixpre at B&H:
"Low-cut filter switches eliminate noise caused by rumble, wind and proximity effect at 80Hz or 160Hz (user switchable).
[/url]
Yep, you're right! I forgot about those little switches on the side. Mea Culpa.
(I would have seen them if I took it out of the case.)
Thank you, Marco!
Ben Chiu is offline   Reply With Quote
Old December 12th, 2005, 03:07 PM   #17
Cut1 and MixPre manual
Originally Posted by Jim Feeley
The Cut1 is the way to go. But your MixPre can help a bit. The high-pass filters are on the side panel next to the Mic inputs and below the tape out. If you don't have it handy, you can download the MixPre manual here:
<http://www.sounddevices.com/products/mx2master.htm>
Hope this helps,
Jim
Thank you, Jim. That's what I was afraid of (the cut1 costs more than most of my old mics!). I'll play with the high-pass a bit (and probably add the cut1 to my wish list).
Best!
Ben
