Sennheiser & A1 audio setup at DVinfo.net
All Things Audio
Old March 16th, 2007, 01:34 AM   #1
Hi everyone,
I'm new around here so forgive me if this question has been asked already.
Just wondering if the Sennheiser ME-66 shotgun will fit into the side of the mic holder on the Canon A1 or do I need some kind of an adapter?
Should I use a shockmount to keep the mic away from the camera?
I film mostly run & gun shots so which shockmount do you recommend for this particular setup?
I'm a little confused about the different Rode models SM3/4/5 could someone
explain what each models does?
peace smiles,
kajito
Kajito Nagib is offline   Reply With Quote
Old March 16th, 2007, 02:42 AM   #2
Location: Oxford, UK (until 2008: Lhasa, Tibetan Autonomous Region)
I think you need to add a few layers of gaffer to use it on the camera :) At least that was the case with the XL1 and the K6. But wait for answer from somebody who has them both.
But the standard mount it's not a good place of a camera mic anyway. I use a combo of Sennheiser mounts (MZS 6 and MZQ 6, if I remember correctly). Works very well, you wouldn't believe it when you look at it. A soundman in Switzerland gave me the tip. We tested it against quite a few other shock-mounts (but not the K-Tek, which gets good reviews on this board) and it does a very nice job. Advantages: small and lightweight. When in a hurry I leave the cables plugged in, remove the mic and place it alongside the camera in my bag. Its much less bulky and square egded than other mounts. With this setup you are ready to shoot within seconds.
Disadvantages: the balance of the camera. It get's a little nose heavy. But what shock mount solution does not affect the balance?
Martin
Martin Saxer is offline   Reply With Quote
Old March 16th, 2007, 07:46 AM   #3
a few layers of gaffer's tape, a rubber adapter; either works. All of the lower cost, on-cam mic holders are a bit big, I'm guessing so that they can hold virtually any mic out there.
Besides, it never hurts to have a little gaffer tape in case of an emergency. Just peel a little off the mic. ;-)
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 16th, 2007, 08:58 AM   #4
I've been using the Rode SM-3 and like it.
http://www.rodemic.com/?pagename=Products&product=SM3
Rode also makes the SM-5 to adapt to camcorder clamps but I think the shoe mount is simpler. The A1 Clamp is removable and it's a little cleaner to transport without it.
http://www.rodemic.com/?pagename=Products&product=SM5
The SM-5 has 2 sizes of threads for pole & tripod mounting too, but I didn't think I'd need that.
Brad Tyrrell is offline   Reply With Quote
Old March 16th, 2007, 11:34 AM   #5
By using the SM-5 would that free up my hot shoe?
Ok, so a few layers of gaffer or a rubber adapter got it!
Thanks for the tip:-)
Old March 16th, 2007, 11:52 AM   #6
Theoretically, - better check dimensions though. Says it's designed for Sony and Panasonic clamps. I just assumed the A-1 clamps were about the same.
I use a Rode NTG-1 and it's sorta hot. The rubber band suspension helps a lot with "touch noise"
Old March 16th, 2007, 11:56 AM   #7
yeah i'll check out the dimension thanks again.
Old March 19th, 2007, 04:36 AM   #8
Kajito,
I am pretty sure that is a 25.2 mm clamp.
If it is an extra shoe you are looking for and to keep the mic off the top check out the J-Rod accessory mount. It was designed to solve the problems you are having and works great. What is has over the SM-5 is the option to put something more than your mic on it ! See it at www.thej-rod.com It can also be removed and put on very quickly for storage in your bag.
ragards.
Jeff Rhode is offline   Reply With Quote
Old March 19th, 2007, 10:47 AM   #9
I'll check it out thanks!
Old March 20th, 2007, 12:22 AM   #10
o-rings
If you slide some o-rings over the mic that works and looks better. Also, the hot shoe on my XH-A1 seems a bit loose after using a hot shot mic mount. I think it needs a reinforcement point not on the hot shoe to help minimize stress.
Larry Vaughn is offline   Reply With Quote
Old March 20th, 2007, 03:14 AM   #11
That sounds like a call to Canon about a warranty issue would fix the problem. The shoe mount should be much stronger than that.
Old March 20th, 2007, 05:46 AM   #12
Works better as a holder or isolator?
My Rode rubber band isolation mount works pretty well. It also looks like it should, - but looks don't mean much sometimes. The look is a little more delicate than I'd like.
The isolation on the built-in A-1 mic is pretty good. My guess is that it's some type of foam/rubber,- isolation with a relatively firm mount.
I really don't know which type of isolation mount works best. I'll bet there is a comparison somewhere. Rubber mounts, foam mounts, rubber band mounts. Anybody got a link?
Old March 20th, 2007, 06:00 AM   #13
I cut off a finger from a washing up glove & put that on the SM-5. Makes a perfect fit when attached to the A1 mic holder.
I did have some explaining to do when it came to washing up though!!!
Gareth Trezise is offline   Reply With Quote
Old March 24th, 2007, 12:15 AM   #14
thanks everyone for your input:-)
-k
