DJ soundboard and digital recorder at DVinfo.net
All Things Audio
Old May 22nd, 2007, 08:45 AM   #1
Can someone explain to how (connectors) and I guess the best way to tap into the soundboard of a DJ. I will be using a Roland R-09 digital recorder.
John
John J. Moon
www.northernlightfilmworks.com - Event DV Top 25 Recipient
John Moon is offline   Reply With Quote
Old May 23rd, 2007, 03:14 PM   #2
Depending on the dj mixer, you can use "record out" rca or xlr(whichever it comes with) or use the "control room" out of the dj mixer to a stereo track input or use a y-adapter(rca to 1/4 stereo tip). If the dj mixer does not have a seperate out then........................I dunno, try useing the amp outs to your recorder monitoring via hjacks.
"Catering to all of your needs, from A to V."
Sam Rosado is offline   Reply With Quote
Old May 23rd, 2007, 05:12 PM   #3
If the soundboard has pre-fader aux outs, try to use those. The DJ is going to be continually changing the main out levels - aux out comes earlier and will be (or at least can be) at a constant level.
Old May 24th, 2007, 09:05 AM   #4
Thanks. I will look into your suggestions.
John J. Moon
