Using both Line level and a Mic level input. at DVinfo.net
All Things Audio
Old July 12th, 2007, 09:42 AM   #1
I'm shooting an interview tomorrow and plan on using my wireless Senn with lav for primary audio and a boomed Rode NT3 for backup.
My A1 only allows for either mic level or line level to be recorded, but not both.
Unless I'm mistaken, the Senn receiver is a line level device and the NT3 (without battery) is mic level.
What options do I have for ensuring that both channels will record good sound? (Phantom power on/off, go with a battery in the NT3, etc.).
Sorry for the newbie questions, but I've just gotten the Senns and have never recorded two channels before.
Dave Smith is offline   Reply With Quote
Old July 12th, 2007, 10:01 AM   #2
I don't have an EW100 G2 receiver here in front of me, but as I recall the audio level can be attenuated as much as 30db in the receiver menu. That should then be in the ballpark of mic-level as seen by your cam.
Do try it today, though. If you're not able to get both mics close enough you'll probably need a mixer.
Old July 12th, 2007, 10:17 AM   #3
Just found an online copy of the G2 manual and yes, the receiver can be adjusted for mic level inputs. One problem down.
I suppose this means that I can disable phantom power for this channel? Or is it auto sensing and not really an issue?
Old July 12th, 2007, 11:47 AM   #4
You should shut down the phantom if the connected device does not need it.
Petri Kaipiainen is offline   Reply With Quote
Old July 12th, 2007, 11:48 AM   #5
Thanks.
Is this just a "good housekeeping" practice or is there really an adverse effect to leaving phantom power on?
Old July 12th, 2007, 01:07 PM   #6
Sennheiser Receiver is Mic Level
Originally Posted by Dave Smith View Post
Unless I'm mistaken, the Senn receiver is a line level device and the NT3 (without battery) is mic level. Thanks!
I think your mistaken. I use my Sennheiser with the Sony VX2100 as a mic level device.
Ron Priest
Louisville, KY
Ron Priest is offline   Reply With Quote
Old July 12th, 2007, 11:22 PM   #7
Sennheiser's reciever output level can be adjusted from line to mic level. Better use line level, less chance of interference, unless you are forced to use mic level signal (like with XH-A1 with mic in the other input).
Phantom: Feeding 48 volts to devices that do not deed it is never good, even though many things do survive it, like dynamic mics and pro electronics. You also run out of battery much faster with phantom running.
Old July 13th, 2007, 03:57 AM   #8
The NT3 is mic level whether you're powering it with its internal battery or with phantom. Without either one, its output is no level at all.
Old July 13th, 2007, 05:52 AM   #9
Thanks for the explanation.
Old July 14th, 2007, 06:25 AM   #10
Thanks.
Hello Dave,
There can be significant problems with some battery powered mics and some phantom supplies.
Even taking a feed from a house mixer to a camera mixer with the camera mixer's inputs set with the Phanton Power on can result in some very nasty audio.
Booming with an NT3!? So you have Superman as a boom op? I don't know many boomers who are capable of booming an NT3. It's way to heavy.
Regards,
TyFord
Ty Ford is offline   Reply
