sonyHD or dsr570 with pstechniks ? at DVinfo.net
Alternative Imaging Methods
Old January 21st, 2005, 11:21 AM   #1
first of all i would like to apologies for doing another comparison thingy-
for my own "projects" and a few lower end fashion spots i can afford about 8 grand-
so im thinking of keeping my money for a sony HD Z1 with a mini35 (leica lenses). downgrading the video to DV in post. (i appreciate neither of these has yet been released).
or should i get a dsr570 and keep my budget for hiring in pro35 and lenses-----
what i am mostly concerned about is the highlights and dynamic range (stops of latitude either side of exposed). make it look nicer and all that.
the other advantages of the z1 setup would be splitting the fields to have (downgraded) progressive scan... as well as possibly 50fps progressive scan?!
hmmmmmm---- pondering
thanx
thomas
thomas english
www.thomasenglish.co.uk
Thomas English is offline   Reply With Quote
Old January 21st, 2005, 01:08 PM   #2
Barry Wan Kenobi
If you want dynamic range, the DSR570 is going to have much wider latitude than the HDV camera.
Your choice is a $15,000 standard-def camera with huge CCD's and excellent dynamic range, superb low-light performance etc., vs. a $5,000 high-def camera that has tiny CCD's, with much less dynamic range and significantly worse low-light performance.
But it's high-def, for 1/3 the price.
If you're going to be working in standard-def and you need the best dynamic range and highlight handling, and can afford the DSR570, the choice is obvious.
If, on the other hand, you value high-def imaging, the choice is obvious.
Barry Green is offline   Reply
