Sony SR12 questions at DVinfo.net
AVCHD Format Discussion
Old March 18th, 2008, 01:53 PM   #1
Sony SR12 questions
Hello,
I'm intrigued by some of the comments I've seen on the SR12. For my application, however, I can't live with the 10,000 foot elevation limit of the hard disk. So, question #1 is this: Does anyone know if the hard drive is completely off and spun down when you are recording to the flash media? To avoid damage, it would have to always be off in this mode, even when powering the camera on and off.
Question #2 regards the quality of the OIS. I tried a CX7 once and wasn't overly impressed with the OIS compared to, say the Panasonic SD1 (and presumably SD9). Does the SR12 show any improvement?
Thanks in advance.
Dave Rosky is offline   Reply With Quote
Old March 18th, 2008, 02:30 PM   #2
Dave, it is my understanding the HDD is parked when recording to the flash drive. If I record to the HDD, I can hear a very very faint clicking as the HDD spins. When I'm recording to memory stick I hear absolutely nothing. So I know it's not spinning and I'm assuming it's parked.
I'm not familiar with the CX7 to give you a comparison between the OIS of both. I have found the OIS of the SR12 to be very good.
Ken Ross is offline   Reply With Quote
Old March 18th, 2008, 03:27 PM   #3
spinning...
I'm fairly sure the hard drive is always spinning. The clicking you hear, are the read/write heads being accessed, & the drive will idle down when not in record/play mode.
PS... what is this 10'000 ft elevation limit on the hard drive? I've not heard of this before.
tumbleweed
Duane Prince is offline   Reply With Quote
Old March 18th, 2008, 03:43 PM   #4
http://www.camcorderanswers.com/manuals/canon_hg10.pdf
page 7
Do not use the camcorder at high altitudes
Turn on or using the camcorder in places with low atmospheric pressure such as
at altitudes higher than 3,000m (9,800 ft), may result in hard disk damage.
Brian W. Smith is offline   Reply With Quote
Old March 18th, 2008, 04:04 PM   #5
Hmm. Thanks for the inputs, but it sounds like there might be some uncertainty. If the HDD is not being accessed, it will not make clicking sounds even if it is powered up and spinning, so the lack of clicks alone is probably not enough to tell. Unfortunately, it would have to be all the way off to avoid damage at high el.
A small hard drive that is spinning but not being accessed is fairly quiet, but might make enough noise to be heard if, in a very quiet room, you hold your ear up to the unit in the area where the hard drive is. Better might be to use a stethoscope, but most folks don't have one.
I'm thinking it might be hard to tell in a store like Best Buy or Fry's because of the high ambient noise level. If it's not possible to know for sure, I probably shouldn't take a risk on the SR12.
Old March 18th, 2008, 04:47 PM   #6
Putting my ear up to the unit with the recording mode set to flash drive, I do hear a very slight humming, so I guess you're right, the HDD is spinning. I wonder why they wouldn't just have it parked when recording to flash.
Old March 18th, 2008, 05:44 PM   #7
Good question. In addition to getting them around the 10,000 foot limitation (admittedly not a big issue for 99% of people), it would also save power and improve battery life a bit when recording to card.
Anyway, thanks for the help, looks like the question's been answered.
Old March 18th, 2008, 05:46 PM   #8
It might depend on how the drive is configured - the key question would be are the heads on the media or "parked" when you're not recording to the HDD - maybe a Sony engineer might know the answer to that, or if you could find out the HDD manufacturer. As long as the heads aren't over the media, the height issue should go away, and you'd record to the MSDuo...
Old March 18th, 2008, 06:30 PM   #9
I just got my SR12 and listening outside in a very quiet location, I can hear a slight noise both with the movie media set to hard disk and memory stick, though it seems a bit quieter with the memory stick option. I don't know why they couldn't turn the disk off (and the noise) with the memory stick, so it would be possibly to get totally quiet and clean audio recordings. Still, after a couple hours with the camcorder, I am overall very happy with it!
http://rockfowl.com/
Ruth Happel is offline   Reply With Quote
Old March 18th, 2008, 08:44 PM   #10
Ruth, I think you'll find that there is virtually no noise from the camcorder that's recorded in the video. The only sound you'll get is the ambient noise around you.
Old March 18th, 2008, 08:56 PM   #11
With modern hard drives, the term "parked" just means that the heads are positioned over the landing zone, which is an area of the disk that does not store data and is designed for the head to make contact when the platter spins down, but is otherwise a normal area of the disk. When the platter begins spinning up (or finishes spinning down), the head is momentarily in contact with the surface while the platter is spinning. The disk is designed for this to occur, but it only occurs for a few hundred mS or so each time the drive spins up or down. The problem with high altitude is that if the pressure gets low enough, there is an insufficient cushion of air and the heads can begin to rub continuously. Even if this happens on the landing zone, the drive wasn't designed to handle this and it can cause damage to the heads. Many people think "parking" means that the heads are physically yanked away from the platter, but that's not the case, at least not with modern drives.
Here's an interesting article describing head parking:
http://www.storagereview.com/guide20...ctParking.html
Hard drives are fairly new in camcorders, but this has actually been a big problem with iPods; you don't have to search the net too long to find lots of stories, despite the warning Apple puts in the manual. Sometimes the iPods worked when they got back down below 10,000 feet (if they were smart enough to turn them off when they first heard funny noises), and sometimes they didn't.
I doubt these big companies listen too well, but what might be worthwhile would be to send a suggestion that they fully power down the hard drive when using cards in their next generation of cameras. The altitude issue probably doesn't affect a large percentage of their users, but everyone would appreciate a little extra battery life.
Old March 18th, 2008, 09:05 PM   #12
That's where I'd be just as happy with a slightly smaller lighter camera with 16-32G flash and no HDD...
Makes me wonder what the "CX9" will look like - love to see the larger LCD, the control knob, and a VF in 100% flash format... The SR11 looks pretty close, but I realize that HDD bugs me a bit as well - I've grown used to the CX7 size and weight, but a bit more size with more features and not much weight would be nice!
Old March 18th, 2008, 09:37 PM   #13
Well, after it got dark I tore myself away from playing with my new toy to loading the footage onto my computer for review. I am very impressed with the image quality, and think the face detection feature is amazing. The exposure may need to be set manually (there was some evidence of blown highlights with a pale face against a dark background) but in terms of locking onto the face with the right focus, I could hardly believe how well it worked. This will solve a major problem I have in shooting when the on camera talent moves enough to throw out focus that I have in the past preset manually.
There is a very slight clicking sound audible when I REALLY crank up my speakers. This won't be a problem for 90% of my shooting. The only thing is, I would like to record good environmental ambience (my background is in doing natural sound audio), and clearly I will still need my Fostex recorder and Sennheiser mics for this. But for recording voice, and anything but really quiet audio, it seems that the mics are very good, and the noise floor is way below that with tape based camcorders. So I am very pleased with this upgrade (I have had the Sony HC7 and the Canon HV20 for the past year, so was looking to get away from tapes, finally).
Old March 19th, 2008, 05:52 AM   #14
Judging from the way Sony upgrades their prior models, I'd look for a CX9 to be a physical clone of the CX7, but with 1920X1080 recording, face detection and most importantly the EXMOR and BIONZ processing.
Old March 19th, 2008, 11:45 AM   #15
Hopefully some improvement in the OIS too ;-) (sounds like the SR12 is better, so maybe the CX9 will be too). I haven't heard that any CX9 has been announced (has it?), so it might be a while before we know the answers.
