Avid / Pinnacle discussions from 2004 - Page 4 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old February 14th, 2004, 02:09 PM   #46
New user - AVID Express Pro
I am a student, and just learning avid express pro, and I think it sucks. Im trying to speed a clip up and then through it in reverse. It will let me speed it up in the composer window, but it looses the audio. Then I can't put the reverse on it. This sucks. I would take Vegas any day!
Michael Estepp
Michael Estepp is offline
Old February 14th, 2004, 08:34 PM   #47
Yes. it works great for effects work and it also outputs After Effects and Photoshop to the 3d monitor.
So I swear by it at the moment.
Director: http://www.mediathreat.com
John Threat is offline
Old February 14th, 2004, 08:42 PM   #48
You will have to apply the effect to the audio track as well.
To apply multiple effects you will have step into to layer or you can hold the alt button down as you drag the effect onto the track for automatic nesting of effects.
Nesting of course is a superior way of adding effects so that you can easily decide which to add or remove or tweak. You can also change the level of the nesting to change the priority of their render on the source material.
Old February 17th, 2004, 01:10 AM   #49
Avid fix
Hey guys and gale got a question for you. After a recent windows update Avid seems not to work with it. Is anyone else having this problem? Has Avid released a fix that anyone knows of? Any work arounds? My school just pulled some machines off the network and uninstalled the last update and runs them that way. But I use it at home and really don't want to have to resort to that. Any input would be great, thanks.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline
Old February 17th, 2004, 05:12 AM   #50
Which version of Avid are you running? There is a known problem with Windows Update KB824141 and Avid Xpress Pro (not sure if this is applicable to other versions). See if you have this installed on your system, and try to uninstall it if you do.
Christopher Go is offline
Old February 17th, 2004, 05:45 PM   #51
You can roll back your system in XP through start > help and support > system restore.
It doesn't take that long.
Glenn Chan is offline
Old February 17th, 2004, 06:06 PM   #52
Just uninstall that FIX and itll work again
Old February 19th, 2004, 01:44 PM   #53
Avid Xpress Pro OMFI files
Is there a setting that would allow for the creation of subdirectories in the OMFI media folder? We currently have multiple projects going on and would like to keep files separate.
Thanks for any suggestions!
Val Daniels is offline
Old February 23rd, 2004, 01:23 AM   #54
Avid defaults to the OMFI directory in the drive with the most free space. There is no practical reason for separating the projects in the OMFI directories. Avid does this by way of the project bins. You can always find out and delete or copy the media files from a particular project via the Avid interface. You CAN force Avid to place media files as they are being digitized in particular drives but, as far as I know, not in specific subdirectories.
Ozzie Alfonso
www.ozziealfonso.com
Ozzie Alfonso is offline
Old February 24th, 2004, 01:30 AM   #55
There is a program media mover that helps you do this.
I do it manually by mapping a network drive to a folder so that windows sees the folder as a drive.
Inside of avid go to the console and type alldrives. it will toggle it to be able to see even pseudo-drives as media drives.
Old February 24th, 2004, 11:41 AM   #56
Hi John,
Where is the console that you're talking about? I am trying to go to avid, but didn't know where i can type in "alldrives". Please advice. Thanks.
Tony Pham is offline
Old February 24th, 2004, 11:44 AM   #57
Nesting Sequences in Avid Xpress Pro!
Hi everyone,
Please advice on how to nesting sequences in Avid Xpress Pro. I couldn't seem to do that. I want to be able to put sequences inside sequences like in PPRO, or making virtual clips like in Premiere 6.5. Please advice. Thanks.
Old February 24th, 2004, 12:30 PM   #58
To get to Console: >tools>console -- also Ctrl +6 (or command 6 on a Mac)
That's as far as I can take you since I rarely go that route.
Ozzie Alfonso
Old February 25th, 2004, 12:36 AM   #59
But isn't this windows update here for a reason? IS there no other way?
Vlog On!
Old February 25th, 2004, 01:17 AM   #60
The updates usually tell you what they're supposed to do. Some of them fix security holes, some fix bugs, etc. You are likely more productive without the update than with it. If you can't run Avid then I don't see you being very productive.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
