AVID Xpress DV Problem Playing back Clips at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old August 24th, 2006, 09:16 PM   #1
Having trouble playing back clips in AVID Xpress DV 4.6 - The clips capture fine, I can shuttle through them fast and the system keeps up. However when I just try and play the clips I can hear the audio playing but no video playing. When I stop it the clip updates to the right frame. Seems I'm just overlooking some simple setting somewhere. Any help would be appreciated. -Jeff
www.m3films.com
Jeff Zimmerman is offline   Reply With Quote
Old August 24th, 2006, 09:46 PM   #2
Are you saying the monitor window is on a freeze frame? Or Blank? IS the track with the video SELECTED (The little monitor icon will show on it).
Richard Alvarez is offline   Reply With Quote
Old August 24th, 2006, 10:43 PM   #3
What a coincidence, I'm having exactly the same problem. I hear the audio but the footage stays still.
I will be KING!
Jaadgy Akanni is offline   Reply With Quote
Old August 25th, 2006, 10:07 AM   #4
Sponsor: Electronic Mailbox
are you running dual monitors? try moving the video window onto the other monitor.
Gary
Check out http://www.videoguys.com 800 323-2325 We are the video editing and live video production experts! DV InfoNet members save 5%! Use Coupon Code DVINFO5OFF
Gary Bettan is offline   Reply With Quote
Old August 25th, 2006, 07:03 PM   #5
Only have a single monitor, video clip windows are not overlapped. Everything in the timeline is selected properly. I search over AVIDs site and was not able to find a solution. I may just trying re-installing the application to see what happens.
If I uninstall AVID will it delete my project and media I have saved?
www.m3films.com
Old August 26th, 2006, 01:22 PM   #6
Avid Video Playback Problem Fixed
Found out if I just updated my video card with the latest drivers the problem went away. Video plays fine. Realtime with no delay.
Thru the whole process I tried re-installing AVID and did all the Windows XP Home updates possible. All settings in AVID Xpress DV are set at default.
The system specs were:
AMD Athlon +2500
1GB DDR 2700 Ram
80 Gig Hard Drive 7200rpm for media
AGP 8x nVidia 5200 fx video card
Sony CD-Burner
Abit Motherboard
On-Board AC-97 sound card
Things are running smooth now. Thanks.
www.m3films.com
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
