best LANC control for C300 at DVinfo.net
Old August 8th, 2012, 03:04 PM   #1
I need a quality Focus control for my C300......any advice???
Chris Atebr is offline   Reply With Quote
Old August 8th, 2012, 05:07 PM   #2
Re: best LANC control for C300
I'm liking the Libec ZFC-5HD.....it works on both LANCs(Canon,Sony) & Panasonics.....
Libec Zoom Control ZFC-5HD - Filmtools
Jim Martin
Filmtools.com
Jim Martin is offline   Reply With Quote
Old August 8th, 2012, 06:02 PM   #3
Those lanc controllers don't really control focus do they?
I have not tried, but I thought the USM motors wouldn't support focus.
Art Aldrich is offline   Reply With Quote
Old August 9th, 2012, 02:00 AM   #4
Yes - The lanc control does allow you to adjust focus.
I have a Manfrotto Pro Lanc controller and it works fine. But whether it's better than adjusting the focus directly is another question.
Another advantage is that it allows you to turn the camera off or to sleep which is pretty handy as it takes less time for the camera to become active than with the switch on the camera body.
The best thing would be for you to take your camera to a dealer and try one out to see if it would work for you.
Mark Dobson is offline   Reply With Quote
Old August 21st, 2012, 08:25 AM   #5
I remember Manfrotto had announced two electronic remote controls for pulling focus in Canon DSLRs. How are they? Will they work with the C300? I have not had any experience beyond reading the press release. Curious to know.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old September 16th, 2012, 07:21 AM   #6
Sadly I tried a number of LANC Controllers from Monfrotto stable ONLY could attempt Rec Start/Stop function. Havet tried the multi button & display type LANC of Monfrotto.
Any updates from your part of Globe
Roger Pinto is offline   Reply With Quote
Old September 23rd, 2012, 09:53 PM   #7
Are you guys saying that the LANC controllers for XF105 and 305 don't work on the C100 and C300? (I know the C100 is not shipping yet).
Al
Upper left hand corner of the map
Al Bergstein is offline   Reply With Quote
Old September 25th, 2012, 05:39 AM   #8
Seems to be conflicting post here. Does the Libec ZFC-5HD control focus? I know it controls zoom and start/stop record.
Paul Cronin
www.paulcroninstudios.com
Old October 22nd, 2012, 05:52 PM   #9
So can anyone confirm that either the Manfrotto pro or Libec controllers DO actually adjust focus on the C300? (or any other LANC controller?)
This would be extremely handy if any of them work, and work smoothly.....
www.zooprax.com
Derek Reich is offline   Reply With Quote
Old October 23rd, 2012, 03:08 AM   #10
I'm using the Manfrotto 521PRO on an XF300, and while Ihave not had this camera long, I have not been able to make it adjust focus. IIRC it worked fine in this respect with a Sony HC1 Everything else works OK with the XF300.
Just looked it up in the Manfrotto Lanc controller pamplet, and it specificially says no push AF with some Canon cameras
http://www.manfrotto.com.au/PDFPages...ontrollers.pdf
[EDIT] responding to Derek's question above, the 521PRO gives me the same smooth control of zoom speed as the main camera zoom control, and it puts the camera to sleep and wakes it quickly. The push AF control on the 521PRO also locks in a slower zoom speed.
Stills at: www.flickr.com/photos/trevor-dennis/
Last edited by Trevor Dennis; October 23rd, 2012 at 03:12 AM. Reason: Addendum after [EDIT] comment
Trevor Dennis is offline   Reply With Quote
Old October 23rd, 2012, 08:01 AM   #11
Thanks, Trevor
But I'm specifically interested in if any LANC controller will adjust focus remotely for the C300. There is no possibility of zoom control on these cameras due to the type of lenses they use, so the only functions of importance would be focus and/or aperture. Either one would be an asset, both would be spectacular.
Anyone have any information in this area?
www.zooprax.com
Old October 23rd, 2012, 10:34 PM   #12
Can the multibutton lanc controller from Monfrotto be programmed to control various feature of c300 programmable switches
Old October 25th, 2012, 09:33 PM   #13
It seems I was too hasty in dismissing my Manfrotto 521PRO's ability to adjust focus on my XF300. Push AF still seems to be beyond it, but I discovered today that when the 'Manual Focus' LED is lit, the rocker does indeed adjust focus. It's a bit slow, and in bright daylight, I would not want to rely on it without Peaking switched on, but yes it does work.
