Canon EOS C100 - Page 7 at DVinfo.net
Old September 11th, 2012, 01:30 PM   #91
Re: Canon EOS C100
I wounding what UW housing they was using ('caz all shoots was from the C100, right?). Is the gates housing supporting C100 too !?!
Markus Nord is offline   Reply With Quote
Old September 11th, 2012, 02:33 PM   #92
Re: Canon EOS C100
I imagine they just adapted the one for the 300/500
Mark Koha is offline   Reply With Quote
Old September 11th, 2012, 02:33 PM   #93
Re: Canon EOS C100
Originally Posted by Mark Koha View Post
Excuse my ignorance, but why is 60p so important for slow mo? And are people really using slow mo that much that it's a make or break deal for a camera?.....
It depends on your line of work. For my line of work I've been very happy to have slow-motion at my disposal. Real slow-motion has such a different look then post slow mo. I'm not happy this cam doesn't have 60P but the resolution for me, nd filters, sensor size, and price is worth sacrificing slow-mo. It may not be for others. It's a tough call. My AF100 does not meet the resolution nor sensor size I can with the C100. No win for this next season for me. Oh well. In the end it's a tool. Others have specific needs then others.
Monday Isa is offline   Reply With Quote
Old September 11th, 2012, 03:22 PM   #94
Re: Canon EOS C100
my main line of questioning is why 60p is better than 60i for slow mo.
Old September 11th, 2012, 05:37 PM   #95
Re: Canon EOS C100
60i isn't slow motion, it's interlaced.
http://www.markoconnell.org
Mark OConnell is offline   Reply With Quote
Old September 11th, 2012, 05:52 PM   #96
Re: Canon EOS C100
Also I believe all LCD/Plasma displays are progressive not interlaced. So to use 60i as slow mo you're using 1920X540 once interpolated instead of getting a full 1920X1080 with 60P. You're losing resolution with 60i once using it for slowmo.
Old September 11th, 2012, 07:13 PM   #97
Re: Canon EOS C100
60p isn't slow motion either until it's played back at a different speed. You can watch 60p video all day long played back at 60 frames a second and it won't be slow motion.
Old September 12th, 2012, 03:51 AM   #98
Re: Canon EOS C100 & Atomos Ninja 2
I liked the last line best!
Old September 12th, 2012, 12:11 PM   #99
Re: Canon EOS C100
Originally Posted by Jim Giberti View Post
The one thing that's really obvious from the behind the scenes is that they didn't consider the EVF to be quite up to par, as they had a Zacuto gaffer taped to the LCD.
Where do you see this, btw? They look like loupes to me. Or is that what you mean? (doesn't seem particularly significant if it is). Maybe I missed something.
Murray Christian is offline   Reply With Quote
Old September 13th, 2012, 03:33 PM   #100
Re: Canon EOS C100 and Zacuto Z-Finder
Looks like Zacuto have all their add ons already covered/tuned for the C100.
Old September 13th, 2012, 10:49 PM   #101
Re: Canon EOS C100
True true true...
Old September 14th, 2012, 04:37 AM   #102
Space Hipster
If Canon had put a proper EVF on the C100, instead of that ridiculously small .24" peephole, Zacuto wouldn't have needed to build anything.
Old September 14th, 2012, 05:52 AM   #103
Very true!
Although I normally prefer a shoulder mount, I think the C100 is small enough to pull off this style of design, just a shame they deliberately crippled it with a small EVF and consumer codec when the far cheaper XF100 has 50Mbps 4:2:2.
Clearly they are protecting the C300 but makes you wonder what the difference in production cost is between a C100 and C300. It makes the C300 price hike seem very steep.
www.mikemarriage.com
Mike Marriage is offline   Reply With Quote
Old September 14th, 2012, 06:43 AM   #104
Re: Canon EOS C100
Originally Posted by Mike Marriage View Post
Very true!
The EVF & screen look very like the ones on the XF100 & the EVF on that is pretty useless. In fact I just looked up the specifications & while they are identical in size 0.24" EVF & 3.5" screen the EVF on the C100 does have a higher resolution at 960x540 versus 640x480 on the XF100.
Old September 14th, 2012, 06:59 AM   #105
Re: Canon EOS C100
I agree, have an XF100 as a little C cam and although I like it, the EVF is one of the weakest aspects. Hopefully the C100's is significantly better.
