Canon EOS Final Cut Plugin will work with T2i - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old June 22nd, 2010, 10:26 PM   #16
Ummm, please pardon my ignorance, but once this is installed and hacked, is it supposed to allow you to "import" your video clips into FCP, or is it supposed to allow you to "Log and Capture" from the camera directly plugged in?
Cole Seidl is offline   Reply With Quote
Old June 23rd, 2010, 09:43 AM   #17
It allows you to "Log and Transfer" from the SDHC memory card loaded into a card reader. "Log and Transfer" should appear just below "Log and Capture" in the Final Cut menu.
George Strother is offline   Reply With Quote
Old June 23rd, 2010, 11:15 AM   #18
Okay, thanks for the clarification.
Old July 19th, 2010, 04:26 AM   #19
I'm running FCP 6.06 on OsX 10.4 on a G5 Quad and am not getting anywhere. Can't even find the link for the plugin- page changed or something, can't find it when searching the Canon site.
Any suggestions?
www.imaginevideo.nl Just published the second of my viral mini-doc series '100'
https://youtu.be/ZqHFBrV-oOc
Jeroen Wolf is offline   Reply With Quote
Old October 8th, 2010, 06:52 PM   #20
Thanks for pointing out that we could use the Safari browser to get to the file location! I kept searching for the file and trying to "cd" to that folder with no luck!
You're instructions worked perfectly for me.
Originally Posted by James Miller View Post
Pipped to the post on that one.
'Cameras.zip'
Download at:
http://files.me.com/jamesfilm/eo665w
Supported Cameras:
Canon EOS-1D Mark IV , Canon EOS 5D Mark II, Canon EOS 7D, Canon EOS REBEL T2i (US) Canon EOS 550D (UK), Canon EOS REBEL T1i (US), Canon EOS 500D (UK)
1. Install the new Canon EOS MOVIE Plugin-E1 for Final Cut Pro.
Available from the Canon website.
http://gdlp01.c-wss.com/gds/5/020000...e1100x.dmg.zip
2. Type this in Safari web address: //Library/Application Support/ProApps/MIO/RAD/Plugins/CanonE1.RADPLug/Contents/Resources/cameras.plist
2. Replace the cameras.plist with the supplied version.
This code lists both US & UK Canon DSLR cameras with video recording functions. Crop mode is not supported on the T2i/550D.
Eric Harnden is offline   Reply With Quote
Old October 8th, 2010, 06:54 PM   #21
Btw
Does anyone know if this will work with the new 60D?
Old August 24th, 2011, 11:56 PM   #22
Re: Canon EOS Final Cut Plugin will work with T2i
I just followed all these annoying steps and finally got it to register the T3i and now FCP will Log and Transfer and recognize the T3i. What a pain that was. But it worked! Changed my cameras.plist file to:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>60D</key>
<array>
<string>Canon EOS 60D</string>
</array>
<key>1D</key>
<array>
<string>Canon EOS-1D Mark IV</string>
</array>
<key>5D</key>
<array>
<string>Canon EOS 5D Mark II</string>
</array>
<key>7D</key>
<array>
<string>Canon EOS 7D</string>
</array>
<key>T3i</key>
<array>
<string>Canon EOS REBEL T3i</string>
</array>
</dict>
</plist>
Event Videography, New England
www.timothybakland.com
Tim Bakland is offline   Reply
