Card reader for T2i? at DVinfo.net
Canon EOS Crop Sensor for HD
Old May 4th, 2010, 11:40 AM   #1
What card readers are you guys using with your T2i?
Skye Giebink is offline   Reply With Quote
Old May 4th, 2010, 02:04 PM   #2
I've got a cheap Targus reader from Kmart. Not sure there's much difference between the card readers on the market. Could be wrong though :)
Evan Agee is offline   Reply With Quote
Old May 4th, 2010, 02:12 PM   #3
Just make sure it's capable of reading SDHC (as opposed to plain-jane Secure Digital). Most older card readers, and some new ones that are cheap, are not SDHC compatible.
Old May 11th, 2010, 05:16 PM   #4
Most modern PCs will read SDHC cards plugged into the SD slot. If yours is over 2 years old it may not but it's worth trying before you buy a reader.
Otherwise search B&H for SDHC card readers, set relevance for price low to high and check them out.
I used to get a real simple SanDisk reader that took an SDHC card at one end and the other plugged into any USB 2.0 port. The ones I got were packaged with a 4GB SanDisk Ultra II card, but I haven't seen any packaged like that since.
If nothing at B&H strikes your fancy try amazon
Old May 11th, 2010, 10:03 PM   #5
I bought a Targus too, I think at Walmart, its much faster than the one that was on board by Dell XPS 420, which is about a year and a half old....
Chris J. Barcellos
