IndiFocus Components Question at DVinfo.net
Canon EOS Crop Sensor for HD
Old August 18th, 2010, 06:49 AM   #1
I intend to buy IndiFocus for T2i. But I am confused as to what all minimum components to get to make the follow focus work.
Should IndiFocus Mini (indiSYSTEM - indiFOCUSmini) is sufficient or
should I also need to get rails to make it work.
Rails link (indiSYSTEM - indiRAILSpro 12).
Also it mentions about whip and crank and the gears, do i need them also? TIA
Subbu Vedula is offline   Reply With Quote
Old August 18th, 2010, 09:07 AM   #2
you definitely need a rail system to be able to mount the follow focus. The whip and crank are just added accessories, the whip is for your camera assistant if you have a focus puller and the crank is for easy quick focus pulling.
The gears come with the focus package also.
Kevin Pineda is offline   Reply With Quote
Old August 18th, 2010, 10:36 AM   #3
I just ordered the 12 inch rail system and the indi focus pro instead of the mini. I hope it will work with my 7d.
I sent the company an email a couple of days ago and asked what they recommended but I got no response. I needed it for a shoot on Thursday so I took the chance and ordered it any way.
Just waiting for the truck.
Ron Little is offline   Reply With Quote
Old August 18th, 2010, 12:03 PM   #4
I bought an 18 inch Indie rail set , which allows for front mounting of my DFocus follow focus, and rear mounting of my Marshall monitor and an addition of a shoulder rest (DIY)
Chris J. Barcellos
Old August 18th, 2010, 01:28 PM   #5
Thank you all.
Old August 19th, 2010, 12:57 AM   #6
Good luck getting response back from them. They don't return my phone call nor emails.
I bought both IndiFocusMini and Jag35 DFocus. They both require rail to mount. I coudln't get dFocus to work as I have a battery grip that raised up the T2i. However, IndiFocusMini works that way.
I read from Jag35 web site, you can get the dFocus, and a dMount so you can mount the dfocus through the 1/4 thread at the bottom of the camera without using rail.
LA Color Pros Blog
Old August 19th, 2010, 07:12 AM   #7
Are you happy with the quality of the indiFOCUSmini? Has anyone used the indiFOCUSpro?
I want to buy some more stuff from them but now the web site will not add anything to the cart. I hope their stuff is better than their service.
Old August 19th, 2010, 07:33 AM   #8
Yep, their service is horrendous. I ordered a set of rails a few months back. After a couple of weeks of getting no replies to my emails requesting the status of my order, I finally threatened to file a paypal dispute to get my money back. A few hours later I received an email with fedex overnight tracking info.
Joe Pasarela is offline   Reply With Quote
Old August 19th, 2010, 09:11 AM   #9
I'm happy with the slider, especially for that price. However, there's really no support and only 1 product image I can find in their web site. Also, it takes like 2 weeks to get the item. There is no communication in between whatsoever.
I have both dFocus by Jag35 and IndiFocusMini. I would say Jag35 has a better quality product. At least it comes with insturctions. However, I have a battery grip with my T2i. Jag35 dFocus won't work in such combination but Indifocusmini does.
LA Color Pros Blog
Old August 19th, 2010, 09:37 AM   #10
Taky, I have the T2i and grip as well. And my D|Focus does work with both rails and the D|Mount.
D|Mount | Jag35.com
What you will have to do is raise the D|Focus up vertically, by adjusting it's height.
While it does work with rails, as I use it on my DVMulti Rig with rail block, I prefer the D|Mount. As I don't have to worry about the added bulk of rails or rail blocks.
The only issue with the D|Mount, is that I have to change to configuration of the mount itself, if I want to sue a long lens. With rails, this isn't needed.
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply With Quote
Old August 19th, 2010, 09:57 AM   #11
Michael, how ca you adjust the height of DFocus? I have their new Version 3...not sure how to adjust the height.
I got email back from Jag35 Kevin saying it won't work with DSLR with battery grip. They plan to make an adapter but they don't know when they will have it done.
"At the moment we are not selling the part that you need to be able to use the D|Focus with a battery grip. We are going to be releasing the extension piece in about a week that will allow your D|Focus to move up and down so that you can use it like in the picture you have attached. "
I filed RMA request to send it back.. as i think that's quite an crucial information that is missing from their product page. If I can adjust the height, I will keep it since I have 3 T2i.
LA Color Pros Blog
Old August 19th, 2010, 10:14 AM   #12
Taky sorry typo on my part.
I am able to use the T2i with battery grip with the Follow focus and D|Mount.
The D|Mount gives you the ability to raise or lower the vertical height.
If you take a look at this image you'll see what I'm talking about.
http://jag35.com/new/wp-content/lg-g...lr_v2-grip.jpg
But the Follow focus by itself will not let you do this.
Michael
www.lvpvideo.com
Old August 19th, 2010, 10:19 AM   #13
Interesting... so the dMount allows me to raise the dFocus? I don't know why Kevin at Jag35 wouldn't recommend that to me.
LA Color Pros Blog
Old August 19th, 2010, 04:32 PM   #14
I don't think it's actually raising the Dfocus, but the Dmount does make it manageable to be used with a battery grip with some adjustments just as Michael said. Here are my pics.
IndiFocus Components  Question-img_2024.jpg   IndiFocus Components  Question-img_2025.jpg
Sean Woods is offline   Reply With Quote
Old August 19th, 2010, 05:32 PM   #15
I got email back from Jag35. I bought the dFocus V3 which is the new version smaller gear and won't work like the old version. Won't be able to adjust the height. That's some new version or product that actually diminish functionality. Returning it!
LA Color Pros Blog
Taky Cheung is offline   Reply
