wide angle on APS-C sensor DSLR - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old November 2nd, 2010, 05:46 PM   #16
That was wide open.
Kin Lau is offline   Reply With Quote
Old November 22nd, 2010, 10:38 AM   #17
OK thanks.
Is there something as good as the canon diopter on the market with a 67 mm thread. I couldn't find it.
If bot, would it be better to get a 67-77 step up or by a close up filter from another brand?
Rob deJong is offline   Reply With Quote
Old December 8th, 2010, 05:22 AM   #18
It's a bugger how these factors sneak up and catch you out. I use Canon 1Ds3 and 1D4 bodies for stills photography, and wanted an ultrawide for the 1D4 (APS-H or 1.3) but there is very little choice. There are plenty for APS-C, but other than the Sigma 10-22mm I am not going to be able to shoot video as wide as I'd like to with the 1D4. The thing I had not even thought about this being a problem until it became a problem - if you know what I mean.
Trevor Dennis is offline   Reply With Quote
Old December 12th, 2010, 12:45 PM   #19
any of these adapters in front of the lens will cause problems. if you want to use a close up diopter I'd only recommend a #1. anything more will make for aberrations that will be objectionable.
the best solution, and also cheaper solution is extensions tubes. you can get a 3 tube set ( 12-15mm, 21, 32-36 ) set with lens coupling pins for iris and focus for about $80 on ebay. be sure you get ones with METAL not plastic lens mounts. the shortest one will probably work fine, but if you need closer, you can change tubes or add them in combination. needless to say DoF becomes extremely shallow and a macro focusing rail might also be on your shopping list.
I've use a tamron 17-50 which focuses really close to start with this way, as well as a OM 50 1.4 with good results.
you'll find even F16 to be shallow.
if you want to get close and far away in focus, try a SPLIT diopter, 1/2 filter 1/2 nothing.
Steve Oakley DP • Audio Mixer • Editor • Colorist
http://stevenoakley.com
Steve Oakley is offline   Reply
