Flycam Nano on 60D at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 13th, 2010, 03:34 PM   #1
Flycam Nano on 60D
Hi,
Read a bunch of reviews on cheesycam.com about flycam nano. I just want to see if the dvinfo community had used the Flycam nano with 60D and see what's your experienced with it.
Aaron Leung is offline   Reply With Quote
Old January 12th, 2011, 12:58 PM   #2
Hey Aaron,
I personally have the 60D and the Flycam Nano. I use the this set up paired up with my 16-35mm 2.8 L II lens which is a monster. I have it balanced but not perfect. needs to be fine tuned. Im running 6 weights back and 3 front. it works great and it can defitnitley handle it. the 16-35 lens i have on it is huge. so its hard to balance, but as i said it needs to be fine tuned. im thinking about using my 60d with my 50 mm prime lens. the lens would be smaller and i may be able to really get it balaced 100% but then i would be at a 50mm on a cropped body.
Fabian Malovini is offline   Reply With Quote
Old January 12th, 2011, 05:24 PM   #3
Hi Fabian,
Thx for the reply. I couldn't wait so I got the flycam nano as well.
I use it to fly: 60d+Tokina 11-16mm f/2.8
Since it is my first time using a steadicam, I had a hard time finding the balance. And once I find the balance (sort of) and had to remove it from the "slow" release plate, it means I need to re-balance over again when I need to put it back. So, I ended up installing a Manfrotto 577 QR mount on the flycam. With the Manfrotto 577, it adds another 1/2 lb to the flycam, but I think it is well worth it.
Like you, I still needing to fine tune the balance.
