Exporting 640x480 7D Footage at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 11th, 2011, 12:01 PM   #1
I recently shot video in the Canon 7D's 640x480 mode. I took that footage, converted to AppleProRes and edited it in Final Cut. The final video runs at about 94 minutes.
When I try to export from Final Cut (Quicktime Export/Current Settings) I either get a General Error or a File I/O Error. I tried sending the sequence to Compressor and exporting it there (Apple ProRes) and I get a 94min video file that's just a black screen with about a second of audio that loops itself for the entirety of it.
Any ideas?
Jon Salimes is offline   Reply With Quote
Old January 11th, 2011, 01:41 PM   #2
might be a couple of things going on
- this might be overly simple, but did you by any chance lock your V track?
check your sequence setting too, they might not be what you are trying to export
otherwise, use quicktime conversion and put it back to something like H.264 for export.
I am not the codec expert but Prores seems to primarliy be an editing codec whereas H.264 is a playback codec
Chris Westerstrom is offline   Reply With Quote
Old January 11th, 2011, 02:00 PM   #3
I'm attempting an H.264 export right now. Probably gonna take a day so I didn't want to try that until last.
Any idea if the length of the video at 94mins (aside from any codec/frame issues) might be the problem? I've never tried exporting anything longer than 10 or 15 minutes.
