magic lantern 550d and audio monitoring at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 27th, 2011, 04:13 PM   #1
will the latest firmware update allow audio monitoring through the a/v out jack? if so, can the volume be controlled?
Brian Tori is offline   Reply With Quote
Old January 27th, 2011, 04:47 PM   #2
I think it can be monitored already. It is line level (−10 dB) so you can't just put earphone on it. You'll need a small amplifier. Maybe there is a hack to make an amp from an old MP3 player....
Keith Forman is offline   Reply With Quote
Old January 27th, 2011, 05:10 PM   #3
I should have said monitoring through headphones. Apparently the magic lantern software has output level control. I would like to know if it works and if the level can be adjusted.
Old January 27th, 2011, 05:11 PM   #4
No. Not without an amplifier.
Old January 27th, 2011, 05:48 PM   #5
I thought I read you can. Why not install it and find out?
"I also was able to get headphone monitoring up."
http://www.dvinfo.net/forum/canon-eo...lantern-6.html
Greg Fiske is offline   Reply With Quote
Old January 27th, 2011, 05:59 PM   #6
Output is currently through the USB port, so you'll need an adapter or headphones with the same kind of audio-to-USB interface that Canon chose uses. In early test versions, audio would come out so hot that it would clip headphones, so I don't think volume is a problem.
However, the way ML now handles audio monitoring may be completely different than the aforementioned test builds. As such, I have no idea how it works now, I just know it is possible to get a very loud signal out of the camera.
Renny Hayes is offline   Reply
