cokin vs tiffen for uv haze 43mm at DVinfo.net
Canon EOS Crop Sensor for HD
Old July 9th, 2013, 12:50 PM   #1
any opinions for "one" of these on the EOS M? same question for some ND filters.
Alex Anderson is offline   Reply With Quote
Old July 9th, 2013, 02:40 PM   #2
DVi Contributor
Re: cokin vs tiffen for uv haze 43mm
Both companies make great filters, so I can only add that I usually buy Schneider filters when needing threaded sizes due to the use of brass. Brass rings will not accidentally lock onto the lens or each other like aluminum does
Craig Chartier is offline   Reply
